Installing new Ignition???
Old Jul 29, 2010 | 11:51 AM
4runner530's Avatar
I have not been able to start my 95 runner. the key no longer turns the ignition over I tried everything so I have a new kit here at home to put a new ignition in but I have never done it before, any advice on how to knock this out??
Old Jul 29, 2010 | 12:15 PM
DeathCougar's Avatar
What exactly are you replacing, and what "kit" are you using?
Old Jul 29, 2010 | 02:36 PM
4runner530's Avatar
I need to replace just the part where the key goes in... The one I had was not for my truck so I am thinking about going to kragen or auto zone to get one there like 50 to 60 buck, just hoping that will fix the problem
Old Jul 29, 2010 | 02:42 PM
You have two options then.
1. Turn the key to "Acc" the depress a small button on the bottom of the switch housing. This will allow the cylinder to slide out.
2. Failiing that option if the cylinder refuses to turn, you have to drill that pin out. Be VERY careful not the damage the aluminum housing.
You can also go to a wrecking yard and get a new ignition switch assy with housing for roughly the same cost.
Old Aug 1, 2010 | 10:58 AM
4runner530's Avatar
thanks i just picked up the drill so hopefully it works
MO transplant
Apr 23, 2023 11:58 AM
Sleaker
Aug 26, 2020 06:03 AM
TDonkey
Jul 26, 2015 10:14 AM
rushw
Jul 18, 2015 01:46 PM
94whiterunner
Jul 12, 2015 07:15 PM
