3.0 starter going?
Old Jul 24, 2006 | 09:33 AM
anniesball's Avatar
3.0 starter going?
I have a '94 4Runner v-6 5-speed. Every once in a while when trying to turn it over it sounds like the battery is dead. If I switch the key on and off for a couple of times it will start right up. It turns out that my battery is properly charged. So that shouldn't be an issue. I am able to push start it just fine, it just won't start with the starter consistently.
Do I need a new starter or is there a solenoid?
Thank you!
Old Jul 24, 2006 | 09:35 AM
1985 4Runner's Avatar
I just had this exact problem & changed the starter. no more starting probs.
AlaskaToy's Avatar
99% chance its just bad contacts. Roger brown sells a kit: cheap fix and a hell of a lot cheaper than buying another starter.
http://www.4crawler.com/4x4/CheapTri...OnlineOrdering
Old Jul 24, 2006 | 10:27 AM
Cebby's Avatar
x 2....
Old Jul 24, 2006 | 10:36 AM
anniesball's Avatar
Is there a procedure to replace these?
I'm looking for a procedure to replace the contacts.
Thanks
Old Jul 24, 2006 | 10:48 AM
Elton's Avatar
sure heres a few https://www.yotatech.com/~corey/tech...imrockford.htm
http://www.4crawler.com/4x4/CheapTri...html#Update-II
http://www.4x4wire.com/toyota/maintenance/starter/
http://www.off-road.com/toyota/tech/starter/
Old Jul 24, 2006 | 11:00 AM
Buck01's Avatar
I replaced contacts on my old starter and it didnt help. I eneded up replacing the starter. So far so good.
Old Jul 24, 2006 | 11:58 AM
Firefightertaco's Avatar
I just went and got one from a online junkyard for 70 bucks shipped next day off of a 97 4runner, works great.
Old Jul 24, 2006 | 02:12 PM
joshik's Avatar
gawd, i had the same problem for over a year. lived with "praying for it to start the first time" and then having the nudge/push the truck to get it to start. very ambarassing at times!! did a lot of searching and posting here on yotatech and i decided to rebuild my starter. replaced the contacts and STILL had the problem! so i left it for another month and lived with it. then one day i decided to tear my dash apart and clean up my truck. i remember seeing that an alarm systems can cause the problem too and the prev owner had an old alarm system that no longer worked. so i tore out the brain of the alarm system. still had the problem. during the clicking, i paid careful attn and i could hear a click coming from my dash, near the ignition. so i followed some wires from where the alarm brain was and followed it over to the ignition. i found that a relay (im assuming the kill switch for the alarm) was zipped tied to the wires that connect to the ignition. so i cut the zip tie and left the relay hanging. now it starts EVERY TIME! weird.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Dakotaneu
Aug 15, 2015 07:24 AM
clok
Aug 1, 2015 09:42 PM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
