2wd frame to 4wd truck
Old Feb 9, 2009 | 06:29 PM
bigt's Avatar
i bet you could get a recall on your truck man!@! doesnt matter if the body is shot!!
try that first...
mounting ifs toa 2wd wont happen...
if your planning on spending big bucks and going to a solid axle it can...
you could prolly find a runner with a dead engine ...swap yours in..
do you want a pick?? or will a runner do???
WHEN EVER YOU BUY A TRUCK BRING A HAMMER and tap the frame...
if its not solid please dont buy it!
Old Feb 9, 2009 | 06:31 PM
mudd'dyota's Avatar
this is what im working with, these were taken bout a week after i got the truck
Old Feb 9, 2009 | 06:46 PM
mudd'dyota's Avatar
thanks for the advice "bigt". im gonna call first thing in the morning, im tired of not being able to drive my truck, it was so much fun till the rot got to it. does anyone know, if i can get into the recall, how the procedure goes. do they give me what the truck is worth now, will they give me a new frame? ive never tried to claim a recall
Old Feb 9, 2009 | 06:58 PM
bigt's Avatar
hahahaha
NO THEY WILL buy the truck from you but htw looks of it you would get the lowest amount.. say 1 or 2 grand.. that one they will prolly crush on site so take and tires or anything off before you go!!
but yeah call and see with your vin it cant hurt..if not keep searching craigs list for a frame or cheap 4-500 dollar truck and part it out!
Old Feb 10, 2009 | 06:28 AM
  #25
mudd'dyota's Avatar
well bad news... i called to find out about the recall. and they start at 95's. so im sol there. time to do some fab work and maybe searching for a sas? anyone got some pointers as far as where to go from here?
sorry bout the 12' lift thingy, i was just goin by what the guy who had it before me said it was, i actualyl started taking measurements and lookin at it since its a decient day up here, and its far from that. wanted to correct that.at most, i think it maybe 6. possibly less. sorry bout that false info guys
Old Dec 19, 2011 | 09:30 AM
  #26
muddy chevota's Avatar
these trucks mainly rot out by the gas tank, then it expands from there, take the box off pressure wash frame inside and out and beat with a hammer, if the frame seems like it is beyond fixing but the frame cab forward is ok , what i have done to a few trucks now is build my own frame , just make sure your on a cement floor and the truck does not move, so your measurements dont change get some 2x4 steel tubes and replicate the general frame shape, you can hammer a straight section of this tubing into the frame under the cab for alignment and extra strength as well , order new spring perches and whatever else you need from trail-gear.com and you have a SOLID tough frame you dont have to worry about again
you wont have to go this route ever if you pressure wash the inside of your frame out and spray tonnes of oil inside,
another trick i have seen is to cut big circles on the underside of the frame in the flat spots and weld in big holed washers around the hole to allow dirt/salt and crap to be washed out, preventative frame maintainance is the key
if you have a 90-95 toyota there are little plugs on the back lower side of the cab that allows access to the insides of the rocker panels, always a good idea to open up and spray the heck outta that area with oil unless your panels already have holes in it
Old Dec 19, 2011 | 03:59 PM
  #27
peow130's Avatar
go get a welder, and weld new pieces of steel on. that truck looks beat to hell, and in my opinion, you're better off parting out and starting off with a new one.
lledwod
Sep 6, 2016 07:33 AM
hhsanfor
Jun 30, 2015 06:08 PM
DanStew
Jun 29, 2015 10:46 AM
TheManOutside
Jun 18, 2015 03:32 PM
dlotoy4runner
7
Jul 3, 2002 03:42 AM
