22re TPS replacement - now motor surges repeatedly
Old Jan 6, 2010 | 07:09 AM
4Crawler's Avatar
Was this with or without the TPS plugged in to the wiring harness? Might try unplugging the TPS and see how it runs. I know at some point there was a change in the TPS and maybe you are going from an older to a newer one.
Old Jan 6, 2010 | 08:52 AM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
This was with the harness plugged in.
Old Jun 9, 2010 | 12:37 AM
KODE's Avatar
any updates? did you solve the problem??
Old Jul 3, 2010 | 04:24 PM
fork's Avatar
what he said^
I'm getting inf resistance between idl and e2 no matter what gap is between the lever and stop screw. Time for a new TPS?
Old Aug 2, 2010 | 05:00 PM
  #25
WatsonToyota's Avatar
yeah man... what happened????
....he put on a new TPS and started having problems, now if you or I replace one and have the same issues, this thread is of no help lol
Old Aug 2, 2010 | 05:15 PM
  #26
thralldad's Avatar
Wow there are a bunch of TPS threads!
Old Aug 3, 2010 | 05:21 AM
  #27
yo this turned out to be the IAVC went bad at the same time causing a massive vaccuum leak! My throttle problem is still there.
Old Aug 3, 2010 | 10:48 AM
  #28
BigSwole's Avatar
Iavc?
Old Aug 3, 2010 | 10:51 AM
  #29
iamsuperbleeder's Avatar
Originally Posted by BigSwole
Iavc?
It's actually IACV
Idle Air Control Valve
Old Aug 4, 2010 | 07:43 AM
  #30
I am a real ho for messing that one up - sorry
Old Aug 4, 2010 | 07:51 AM
  #31
thook's Avatar
No need to be sorry. It's also called the auxiliary air valve/AAV. Just wanted to throw that in there......
Old Jan 21, 2012 | 12:46 PM
  #32
Dustin Hopper's Avatar
Hey I've had issues with mine too but mine is like lagging whenever I go from first to second and to third and then I have to punch it for it to go anywhere whats the deal?
Old Sep 15, 2018 | 09:10 PM
  #33
Allison Alexander's Avatar
Iac, tps,
BUMP My 94 22RE is doing the same code 22. Got a new coolant temp sensor. Will install
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
