22re died, wouldnt start, let it sit then cranks up
Old Mar 11, 2010 | 11:59 AM
whitebullet3's Avatar
91 toyota 22re 5 speed. Died while driving down the road like it was out of fuel. Tried to crank on it, it would turn over fine but wouldnt run. temperature outside was above 60. left it over night and came back with lower temps outside rainy day, and it cranked right up, and i trailerd it home. Now ive seen some problems with afm and not sending power to the fuel pump at certain temps or so but? . I am a diesel mechanic and havent worked on many toyotas. Can somebody point me in the right direction on this thing?
Old Mar 11, 2010 | 07:41 PM
Its mostly been cold here and it has ran fine. I travel everyday where the temperature is warmer and the day this happend it felt like a summer day, and the truck started sputtering on me and then on up the road it completely died. I cranked and cranked on it and checked over everything. Then it sat overnight and i went to pick it up and it cranked right up. ?
Old Mar 11, 2010 | 07:58 PM
mightymouse's Avatar
Start with the basics. How is the fuel pressure? Check the AFM. Check the TPS. Check the fuel filter(next to the starter under the intake). Obvious stuff like plugs, wires, dist., cap, rotor, vaccum leaks, Look at 4crawler's site trust me it helps.
Old Mar 11, 2010 | 08:20 PM
alright thanks
Old Mar 12, 2010 | 11:04 AM
balfguy's Avatar
I second the Dist.cap/rotor. I had the EXACT thing happen top me in a VW.
Old Mar 12, 2010 | 12:32 PM
swampfox's Avatar
you might check for spark. sometimes the coil can start to fail and can cause it to die.after it cools down it will work again for awhile.
Old Mar 14, 2010 | 08:16 PM
check for spark when it dies? B/c checking when its cooled down would show spark b/c it would be working properly.
Old Mar 14, 2010 | 09:34 PM
93runner223's Avatar
i had this happen in my 93 it ended up being the fuel pump, the sump was broken within itself causing a blockage for fuel to travel, but the main problem being a broken air bleed off so air would get into the line and then it wouldnt start,
start by checking fuel line for air
Old Mar 16, 2010 | 11:16 AM
Ive ran this thing for over an hour a couple times idling, driving keeping it hot. And I cant get it to spit sputter or do anything again. Ill just have to keep a close eye on things
Old Mar 17, 2010 | 02:07 PM
swampfox's Avatar
if the coil start to break down it will over heat.when it over heats it will stop working until it cools off. this cycle will continue until it fails completely. if your truck has run for an hour and has not died it probably is not the problem.
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
MadMax48
Jul 3, 2015 08:26 AM
luke0927
Jul 2, 2015 10:49 AM
