22r engine rebuild question
Old Jul 3, 2011 | 04:27 PM
runnerfreak88's Avatar
Im rebuilding a late 22r block for my 86 pickup. Im wondering if all the torque specs in the 1985 fsm are the same for the engine. I think they are but I know there were some slight differences between the pre 85 and post 85 engines.
Old Jul 3, 2011 | 07:57 PM
87 'runner boosted's Avatar
Im sure they are, if you tell me specifically what kinda torque specs youre asking about cuz I have an 86 fsm. shoot me a message and ill compare with ya man
Old Jul 4, 2011 | 05:48 AM
Mr.Utah's Avatar
I used the 85 fsm for my 87. However some specs I modified due to recommendations.
Old Jul 4, 2011 | 07:04 AM
hilandfrog's Avatar
:lol
I used my 86 FSM for rebuilding my 94 RE
Of course I spent WAY TOO MUCH time reading threads and downloading numbers from in here to say strictly I only used the FSM
I think the water pump had the largest amount of need more detail.....
Different sized bolts, different lengths some needed RTV some needed lock tight WTF
Using an old box, attach a printed a pic and insert the bolts into the pic adding red circles for the RTV ones, Yellow circles for the lock tight ones and torq speck next to all.... it was the easy way for my little head
Best of luck
Repo
Old Jul 4, 2011 | 03:31 PM
lol I did a water pump on my brothers 22r one time just siliconed the crap out of it. When he bought a new engine were striping it down so I could rebuild it. All the water pump bolts were loose we were like wtf how is it not leaking? The silicone had sealed and secured it lol. it took him pulling the engine and me pulling on the water pump to get it off lol.
Old Jul 4, 2011 | 04:10 PM
oh and thnx for to cardboard and picture tip i had forgotten about that one.
Old Jul 4, 2011 | 08:35 PM
hilandfrog's Avatar
Careful w/ that RTV this is what I found when I was rebuilding mine
Some of that stuff had to have restricted flow and even wound up in places it should not have been, just a thin coating
Repo
Old Jul 4, 2011 | 11:57 PM
wow thats insane lol must not have used to much wasnt like that lol
Old Jul 9, 2011 | 10:51 PM
these are the numbers im looking for if any one knows these are out of the 85 fsm wondering if there their the same for 86
main caps 76 ft-lb
rod bearing cap 46 ft-lb
oil screen assembly 4 bolts 9 ft-lb
fly wheel 80 ft-lb
oil pan 9 ft-lb
crank shaft pulley 116 ft-lb
exhaust manifold 33 ft-lb
intake manifold 14 ft-lb
distro drive gear 58 ft-lb
rocker assembly 58 ft-lb
cam shaft bearing caps 14 ft-lb
head bolt ?
bigjstang
Jun 2, 2025 03:56 PM
jerusry
Oct 19, 2015 05:28 PM
Yota.Jay
Jul 23, 2015 08:08 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
