22r can i use carburated in a fuel injection
Old Sep 23, 2010 | 01:37 PM
adamsfence's Avatar
alright guys i found me a motor on problem is its not the FI...the guy told me that it will fit and all i have to do is bolt up the intake off my motor and it will work.....is this true.. thanks fellows
Old Sep 23, 2010 | 01:42 PM
DROPT's Avatar
yes sir
Old Sep 23, 2010 | 01:43 PM
adamsfence's Avatar
good deal thanks guys getting this motor for little of nothing and i'll be riding....
Old Sep 23, 2010 | 02:16 PM
myyota's Avatar
Make sure to swap the cam from your fuel injected engine over to the carbed engine, there is a small difference in the cams.
Old Sep 23, 2010 | 02:23 PM
HighLux's Avatar
uh....doesnt the 22r have a mechanical fump? have to block that off or something?
Old Sep 23, 2010 | 02:26 PM
1990yota-pickup's Avatar
yes it should.. just be craftie and make a plate for it... to cover it up...
Old Sep 23, 2010 | 09:03 PM
milehigheric's Avatar
You would honestly change the cam?
Old Sep 23, 2010 | 09:16 PM
myyota's Avatar
You don`t have to, but there is a difference between the two cams.
Old Sep 24, 2010 | 11:22 AM
adamsfence's Avatar
in my research i can only say that this is highly debated so i don't know if i should pay these shade tree mechanics to mess with the cam or not.....if it is different how much of a difference will it make in the engine
Old Sep 30, 2010 | 08:53 AM
adamsfence's Avatar
ok guys update on what is happening with my truck.....the motor i put in was a carborated out of an 85. i research and everything was suppose to work well got motor sat in and started bolting the rest of the stuff up and in intake was different. so we said we would just swap heads with my other motor. so we removed the head and to everyones suprise the dadgum pistons are different. the broke motor has flat tops and the other has the round pistons on it. so now i guess im just SOL. 300 out on this junk motor and 400 out to have it installed.......not having a good day.
Old Sep 30, 2010 | 09:05 AM
DROPT's Avatar
well damn. i wish you would have specified the year of the engine. i coulda told you that wasnt going to work. try getting the intake off an earlier model truck?
pre 86 the block and head are slightly different and the 86+
Old Sep 30, 2010 | 09:22 AM
adamsfence's Avatar
only way i think i can do it is to change it to a carb......i found another one going to look at it after lunch.......anyone need a 85 22r motor....i don't
oh well i guess lesson bought.....wife is gonna kill me when she gets all these bills
Old Sep 30, 2010 | 11:08 AM
DROPT's Avatar
what do you plan on using the truck for? at this point as you said you are already in like 700 bucks. the cheapest/easiest route would be run a carb instead of efi. did the motor not come with the carb or intake?
Old Sep 30, 2010 | 04:07 PM
adamsfence's Avatar
already bought another one i wanted it to stay efi...but no it didn't come with intake or carb cause i thought i didn't need it
Old Sep 30, 2010 | 04:19 PM
DROPT's Avatar
wanna sell me the block on the one you couldnt use? i want to make a 20/22r hybrid
Old Sep 30, 2010 | 04:42 PM
adamsfence's Avatar
its for sale make me an offer. i don't need it unless im gonna make a suped up go cart or something.....don't know how you would get it unless your close
sandyota
Feb 4, 2021 11:16 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
