1st gen 4runner sail panel removal
Old Apr 22, 2009 | 10:45 PM
mojo4x420's Avatar
Is there some trick to remove those pannels on 1st gen 4runners that are directly behind the doors?
Attached Thumbnails 1st gen 4runner sail panel removal-4runner-sailpanel.png
Old Apr 22, 2009 | 10:47 PM
85excab's Avatar
yep, the old plastic faseners are gonna break. and u are gonna have to go to toyota and buy new ones. why are u trying to remove them?
Old Apr 22, 2009 | 10:48 PM
StangBanger's Avatar
Aint that a b*&tch..
Old Apr 23, 2009 | 06:22 AM
slacker's Avatar
yep there is a trick .
If you push the bottom forward , it will release the bottom clip . push up and it will release the top 2 clips , then pull down and release the sail panel .
problem is , installing it back on the clips is next to impossable ... and I have never been sucessfull in removing the clips with out breaking them .
http://www.toyotafiberglass.com/4runner.htm has clips way cheeper then the dealer
Old Apr 23, 2009 | 06:23 AM
Outsane's Avatar
You can save a couple of the clips..
they will slide off in one direction, I will get some pics to explain..
Old Apr 23, 2009 | 07:41 AM
mojo4x420's Avatar
Thanks for the info.
Doing fiberglass rear quarter install. I already have the clips.
http://www.toyotafiberglass.com/1_4_install.htm
I've seen it done before, so I knew there must be a trick.
Old Apr 23, 2009 | 07:59 AM
4Crawler's Avatar
Yep, push forward on the bottom to release the bottom clips then push up to release the top clips. I found the drip rail on the roof precluded raising the panel high enough to free he clips fully, but was able to pop them loose with a little pressure. I re-used all the clips by lightly gluing them into the panel:
Also replaced all the rubber flaps on the vent with some pieces of rubber inner tube cut to fit:
Old Apr 23, 2009 | 08:20 AM
Outsane's Avatar
Nice work with inner tube! I need to do that same..
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
ItsJustD
Jul 7, 2015 07:49 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
