1994 Toyota Pickup Vibration
Ok, so I did have a vibration in my truck while driving 40-45 mph and then again and worse at 60-67 mph (did not matter if in gear or in neutral, did not matter if accelerating or decelerating). I got under and checked the rear driveshaft to see if the u-joints were bad and honestly, they were pretty solid, but the shaft had a pretty large dent in it. So i took it off, locked the hubs, and drove off in 4wd to confirm the rear driveshaft was the cause of my vibration. Well the vibration went away! However, there was a new vibration at 30-35 mph, but ONLY when in gear and accelerating/decelerating. The gear choice does not matter. Is this another drive shaft issue?? The front driveshaft appears to be fine (no dents, ujoints are solid), but the vibration is pretty damn violent but the truck is silky smooth before and after. Could this just be because the rear driveshaft is out so that is throwing the whole system out of whack??
Sounds like you have the same vibration I do. I have replace my wheel bearings chasing after it. I think I'm going to pull my drive line and send them out to be balanced. Might also replace my motor and trans mounts while I am at it.
I'd probably check everything else before jumping to tires. I did the same thing, didn't fix mine. Easy way to flush a paycheck down the commode.
PlumberDragon
May 18, 2022 07:37 AM
Blk63vette
Apr 5, 2011 08:13 PM
eno818
7
Oct 10, 2004 04:10 AM
Tyson94SR5
Aug 24, 2004 12:52 PM
