1994 3.0 4x4 4runner with bad fuel leak where rubber meets metal fuel line
Old Dec 1, 2013 | 05:51 PM
mattesonb's Avatar
I have a 94 4runner with 185k miles on it that until now has been doing great.
I drove up to the mountains last night and started to notice a bit of a fuel smell in the cab. this morning it became nearly unbearable within the 15 minute drive to the resort.
we located the leak in the fuel line and its dripping pretty badly, about 1 drop per second after running the truck.
the leak looks to be in the fitting where the rubber tubing has met with the metal fuel rail. fuel is dripping right out the bottom and down the line
it looks to be part #23811B
here are some photo's
Old Dec 2, 2013 | 02:23 PM
mattesonb's Avatar
Bump!
Old Dec 2, 2013 | 02:48 PM
Gevo's Avatar
mattesonb, are you asking if that is the right part number?
I may have missed the question in the post.
Old Dec 3, 2013 | 09:20 AM
mattesonb's Avatar
im wondering if that is the correct part, if anyone has replaced this before, or if there is a way to repair without replacing
Old Dec 3, 2013 | 09:26 AM
Gevo's Avatar
pressure fitted connections aren't really repairable. that number doesn't look like a toyota part number. just google it, should be easy to find.
Old Dec 3, 2013 | 09:59 AM
mattesonb's Avatar
looks like part number is #23801-65040
i'm picking up the part tomorrow, i'm just hoping i can replace without removing the entire plenum
my truck is actually up in the mountains, i am hoping i can jb weld the leak to get the 60 miles to the auto shop.
i dont know what pressure that line is running at but its coming out in a drip and not spraying out.
Old Dec 3, 2013 | 10:03 AM
scope103's Avatar
23811B is the "PNC#". No, I don't know what that stands for.
It translates to part number 23801-65023 http://www.toyotapartsoverstock.com/...rimLevel=18292
Note that this part ends in a "banjo" that connects to the Fuel Pressure Damper. When you replace it, you MUST use new crush washers 90430-18028. Yeah, someone will tell you that you can re-use them, but Toyota says you can't, they're cheaper than dirt, and you're dealing with pressurized gasoline. Don't be cheap-stupid.
While you're at it, examine your Damper for leaks. Happened to me and to others. The screw in the cap is to confirm pressure (it pushes out when the rail is pressurized); don't try to tighten it, and tightening it will do nothing if it is leaking.
Old Dec 3, 2013 | 10:10 AM
scope103's Avatar
Be sure to use your VIN number when searching for a part. Especially at the dealer. And don't ever rely on some stranger on the internet.
You won't be able to replace it without removing the plenum; you can't fit a wrench in there. (Come to think of it, I had to remove the PIPE SUB-ASSY, FUEL, NO.2, which means you'll need four more crush washers (different size)).
Old Dec 3, 2013 | 11:41 AM
mattesonb's Avatar
Hmm do you know what the part number on the other set of crush washers was?
Old Dec 3, 2013 | 03:03 PM
scope103's Avatar
Uh, just follow the link I gave? 90430-12026
Again, use your VIN. I'm 99% sure these are very standard parts, but I do get multiple part nos., so check it carefully.
Old Dec 3, 2013 | 03:08 PM
mattesonb's Avatar
Got it, looks like 90430-12026 time 4
Old Dec 3, 2013 | 03:25 PM
mattesonb's Avatar
Anyone know how to find out the part number for the Plenum gasket?
Old Dec 3, 2013 | 04:25 PM
scope103's Avatar
Ah, jeez mattesonb! What do you think the answer to that question should be?
(If you're just completely lost, Toyota calls the plenum the "air surge tank.")
Old Dec 3, 2013 | 05:05 PM
mattesonb's Avatar
Haha thanks, I have been hunting through page after page and can't find the gasket on the part sites
JF9243176
Oct 8, 2017 04:21 AM
Nathan_F
Aug 19, 2015 04:03 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
JF9243176
Jun 24, 2015 04:53 AM
HALMAN
Jun 14, 2002 09:02 PM
