1988 4runner that i want to put on a 1985 pick-up frame
Old Jun 5, 2009 | 06:41 PM
ykwildtoy's Avatar
i have a 1988 4runner that i want to put on a 1985 pick-up frame for the solid axel. is this possible for a direct bolt, and just put my 22re in or not the pickup engine is a 22r
Last edited by waskillywabbit; Jun 6, 2009 at 02:01 PM. Reason: useful title for searching
Old Jun 5, 2009 | 07:56 PM
4rnr's Avatar
very possible. Just a body swap? or are you going to swap over a couple of the "more desireable" parts from the 4runner (rear axle, steering box if you think you will go high steer, brakes etc...) regardless it should work. Even if the body mounts dont line up make some.
Old Jun 5, 2009 | 11:57 PM
Tofer's Avatar
Sponsor
why not just use the front axle on the 88 and get a SAS kit?
Old Jun 6, 2009 | 12:03 AM
CRafferty's Avatar
^ Because that would be much to easy.
Unless the 4R fame was bent to who knows where or rusted out.
There has to be an underlying reason.
Old Jun 6, 2009 | 03:42 PM
ted's Avatar
ted
x2
Old Jun 6, 2009 | 09:52 PM
myyota's Avatar
Yea, just do an axle swap, it would be a whole lot easier and a lot less work.
Old Jun 7, 2009 | 11:35 AM
ykwildtoy's Avatar
there is a method to my madness the frame was modified with chevy springs and dana 60's , i do think an sas would be easyer but where is the fun in taking an easy way i love to fab and if i could pll this off my truck would be a tank
Old Jun 7, 2009 | 11:47 AM
DeathCougar's Avatar
It will not be a direct swap. The mounts are different, and will have to be fabbed to make it work.
arlindsay1992
Jan 23, 2024 01:34 PM
JF9243176
Oct 8, 2017 04:21 AM
JF9243176
Jun 24, 2015 04:53 AM
Eagle564
Jun 23, 2015 11:29 PM
JaredL
Jun 16, 2015 04:47 PM
