1986 Toyota W56 transmission issues. Input shaft seal??
Old Mar 1, 2023 | 09:28 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I run GL4 75w-90 Redline in my trans. I use GL5 Redline in the transfer and both diffs.
I don't necessarily endorse one oil over another, but I will say Redline reduced my driveline sound over regular house brand 75w-90 by quite a bit.
Old Mar 1, 2023 | 03:48 PM
Boogeyman's Avatar
Got it all cleaned up, painted and ready to go back in.
Old Mar 3, 2023 | 06:35 AM
Boogeyman's Avatar
I got everything in yesterday. Realized I was missing 2 17mm bolts...Shout out to Yotashop for having them in stock. Probably pretty important to have those bolts...Don't know how long I've been without. 😂🤦‍♂️
I noticed my 4wd indicator switch was screwed up..
is this the correct replacement? https://www.partsgeek.com/wtykvdq-to...IaAuzgEALw_wcB
Looks like it might be..Just want to make sure.
Old Mar 3, 2023 | 06:43 AM
Jimkola's Avatar
YT Community Team
5 Year Member
That link doesn't work.
You can't load that terminal back into the connector?
Old Mar 3, 2023 | 07:35 AM
  #25
Boogeyman's Avatar
I stuffed it back in the connector. I might need to get in there and do some soldering.
So that replacement won't work? Im trying to find other options in case I have to swap it.
Old Mar 3, 2023 | 07:54 AM
  #26
Jimkola's Avatar
YT Community Team
5 Year Member
Your link just goes to Partsgeek home page, not to the item you're thinking about buying. Click it and see
Terminals have tabs on them to lock them in place when you slide them into a connector. It'll slide in, but the tab keeps it from coming back out unless depressed. No soldering needed.
If the tab on the terminal got ruined maybe you ll need to crimp a new one on.
here's a picture of a spade terminal with the tab. If the tab is still there, just flattened, maybe you can fix well enough that it locks in. it doesn't take much.
Old Mar 3, 2023 | 08:11 AM
  #27
Boogeyman's Avatar
my bad dude...
Old Mar 4, 2023 | 11:33 AM
  #28
Jimkola's Avatar
YT Community Team
5 Year Member
Looks good. I still think the old one is an easy repair, though
Old Mar 4, 2023 | 02:35 PM
  #29
millball's Avatar
Appears to me that the switch on the tranny is one wire while the replacement shown is two wire.
Old Mar 4, 2023 | 03:59 PM
  #30
Jimkola's Avatar
YT Community Team
5 Year Member
Ok, wait.
The back up switch is two wires, but in your picture with the assembled transmission you have that installed and it looks ok.
So you're looking for the 4wd indicator switch. No, that one from PartsGeek will not work. Not for that. The oem number for the 4wd indicator is 84222-35020 and it's discontinued.
Good catch Millball.
Old Mar 5, 2023 | 09:07 AM
  #31
Boogeyman's Avatar
Originally Posted by Jimkola
Ok, wait.
damn...story of my life!
I jammed the wire back in and it "clicked." I'll remove the whole thing, clean it and see what's going on...The 4wd light isn't IMPERATIVE, but it's nice to have...I let my buddy drive my truck once and he left in 4hi when he hit the freeway to grab me from the airport. 🤦‍♂️🤦‍♂️ No light so he didnt' know.
I just got the electrical wiring diagram book...waiting on the othe vol1 and 2 of the service manual.
Old Mar 5, 2023 | 12:31 PM
  #32
Jimkola's Avatar
YT Community Team
5 Year Member
The 4wd indicator didn’t illuminate before the trans was dropped? You might want to remove the sender and ohms check it for continuity. At the same time jump the connector on the harness to ground and see if the 4wd bulb lights up. With key on of course
Old Mar 6, 2023 | 11:49 AM
  #33
Boogeyman's Avatar
It did...my speedo worked as well, this was all before I had the clutch changed about a year ago. When my buddy did the clutch at his shop my speedo quit working and the 4wd light quit working 🤦‍♂️
I guess I can pull the plug out and see if the end has power. I also changed the speedo wire. That was a huge pain in the ass getting the cable out of the dash..They don't give you much wiggle room. I wanted to pull the cable out of the dash have a little push and see if that thing moves.
Old Mar 6, 2023 | 12:02 PM
  #34
Jimkola's Avatar
YT Community Team
5 Year Member
When you shift into 4wd the plunger on the sender gets push in, completing the ground. So if you go up to the connector where the wire got pulled out just connect a jumper wire to the terminal on the wire harness side and ground it out to the frame. The indicator light should come on. Assuming it does, you then can remove the sender from the trans and just quickly check with you multi meter that you have continuity in the sender when the plunger is pushed in. Connect one probe to the terminal on the wire, with the other probe on the threads of the sender.
If both check out ok you just need to get a solid connection at the connector where that wire got pulled out in the first place.
kooter77
Apr 16, 2021 10:59 AM
Learning
Jul 6, 2017 08:32 AM
KingBouyah
Dec 24, 2016 07:32 PM
rottjr
Mar 29, 2011 04:07 PM
Swansen
Sep 18, 2008 03:32 PM
