Wiring
Wiring
Hi guys Reelal here, today my 85 4runner quit running with ign. switch in run position, will start and run in crank position. I need wiring diagram so as to troubleshoot problem and my fuse box covers are gone as well, need pic of fuse positions, sure would love some help how bout it. Thanks in advance.
22RE? Look for fuel pump check connector, short FP to B pin. Also search how Circuit Opening Relay works on my thread.
OK, I unpluged the TPS and the engine started and ran. Cleaned the plug and connector with contact cleaner, used dielectric grease on both pluged up TPS and all is well. Then did the same on igniter connectors and dist. connector. It is running. Thanks again guys.
So.. Shorted five volt vref in the tps harness probably. Which means when it tried to change from the start to run condition and didn't get ignitor feedback IGf (iirc) it wasn't sending IGt.
yamahabanshee350
Dec 9, 2011 06:40 PM
Dailydriver2
Dec 16, 2005 04:12 PM
Vinman
Nov 1, 2005 12:13 PM
