Wiring
Hi guys Reelal here, today my 85 4runner quit running with ign. switch in run position, will start and run in crank position. I need wiring diagram so as to troubleshoot problem and my fuse box covers are gone as well, need pic of fuse positions, sure would love some help how bout it. Thanks in advance.
FSM search on ebay is your best bet.
Thanks Fishguy, Now lets see if I can get'er goin.
Originally Posted by reelal
(Post 52395892)
Hi guys Reelal here, today my 85 4runner quit running with ign. switch in run position, will start and run in crank pos...
. 22RE? Look for fuel pump check connector, short FP to B pin. Also search how Circuit Opening Relay works on my thread. |
OK, I unpluged the TPS and the engine started and ran. Cleaned the plug and connector with contact cleaner, used dielectric grease on both pluged up TPS and all is well. Then did the same on igniter connectors and dist. connector. It is running. Thanks again guys.
Good follow up. Nice work.
So.. Shorted five volt vref in the tps harness probably. Which means when it tried to change from the start to run condition and didn't get ignitor feedback IGf (iirc) it wasn't sending IGt.
