What is this piece for? 22RE
Old Aug 13, 2009 | 06:19 PM
1990arizona4runner's Avatar
1985 4Runner, 22re w/ manual transmission, A/C, P/S
Where does it go?
Do I need it or can I get by without it?
Another great question from the new guy on his first rebuild. I have so much to learn on organizization and taking notes when taking part in a body swap/rebuild alone.
Old Aug 13, 2009 | 06:26 PM
88toyfreak's Avatar
they are vsv's (vacuum switching valves) I think the blue one is your idle up valve. Makes your engine rpms go up when you turn on a/c or a heavy electrcal load.
The other not sure there is one for egr(different from year to year) and fuel pressure for efi.
They should go on your passenger side above the tire inside eng bay.
Old Aug 13, 2009 | 06:52 PM
I still can't figure out where the hell that thing goes or what vacuum lines go to it. The most trouble I have had with the entire 4Runner build over the past 8 months has been this vacuum line . A word of advice for everyone out there; don't take pictures of your rebuild disassembly with you daughters camera because she will delete them to make more room for pictures of her dog.
If anyone has any pictures of this thing in the truck that would be awesome.
Old Aug 13, 2009 | 07:11 PM
RMA's Avatar
RMA
check out junkers thread.
https://www.yotatech.com/forums/f116...icture-189052/
Old Aug 13, 2009 | 07:22 PM
I already have the ones from Junkers thread accounted for. The ones mounted on top of the engine are hooked up and ready to go. Thanks though.
Old Aug 20, 2009 | 07:27 AM
rbmoomba's Avatar
When I built up my 88 runner those things ate my lunch, recently built my 84 (with a weber) dropped in and rolled out. The manuals area absolutely no help with the vac. lines either
Old Aug 30, 2009 | 01:13 PM
Alright guys, I started my truck today and it won't stay running. Im guessing it has something to do with this piece; I still dont know where it goes. If someone could please take a picture of where it goes and more importantly what goes to it, I would appreciate it.
Old Aug 30, 2009 | 01:36 PM
4Crawler's Avatar
Might be the VSV for the fuel pressure regulator:
- http://www.4crawler.com/4x4/CheapTri...ine_Pix/9.html
Old Aug 30, 2009 | 03:55 PM
Already have that piece on, thanks though 4Crawler. I actually used that page before to hook up all my other vacuum lines.
Old Aug 30, 2009 | 04:20 PM
jrohland's Avatar
Throttle?
The button on the left looks like it is activated by something mechanical like the throttle. I would check around that.
I don't have that vehicle so I can't look for you.
jrohland
Old Aug 30, 2009 | 05:14 PM
4Crawler's Avatar
Only other VSV on my '85 is the one for the A/C idle up. Engine should run fine w/o that part, assuming the affected vacuum lines are capped.
Old Aug 31, 2009 | 04:57 PM
brownbagg's Avatar
I had that same part on a carbed model, it hook to the charcoal canister, it got toss with the canidster
dfarr67
Jul 30, 2015 07:08 AM
PlayAwhile
Jul 20, 2015 11:36 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
crashburnoveride
Jul 10, 2015 06:39 AM
