vacuum lines and timing issues, Help
Old Apr 2, 2013 | 06:38 PM
yodafan93's Avatar
so i finally got my 22rec, 1985 granville 4runner running after a 2 month long head gasket repair. took a while to get materials and funds, along with knowledge and just plain time to do it. anyway.. i keep getting REALLY bad vacuum surging. i am pretty sure i know why. (see picture) i cant find where this connects to on the vacuum diagrams i have looked at. and was hoping you guys could help me out. it wont run if its not plugged up. as far as the timing goes, how have you guys been timing your 22re's? i cant see the crank pully with the belts on well enough to tell. its pretty crammed. any help would be appreciated.
Attached Thumbnails vacuum lines and timing issues, Help-img_20130402_200109_zps18999172.jpg
Old Apr 2, 2013 | 08:39 PM
yodafan93's Avatar
the open vacuum port is right beside the throttle body if you were wondering from the pic. its actually coming out of it.
Old Apr 3, 2013 | 06:41 AM
yodafan93's Avatar
no one knows?
Old Apr 3, 2013 | 11:08 AM
203Cree's Avatar
That line either loops around to the side of your upper intake manifold, on the valve cover side, or it plugs into your aux air valve. I'll figure it out when I get home.
Old Apr 3, 2013 | 11:58 AM
yodafan93's Avatar
okay. if you could take a picture of everything under your throttle body that would be a huge help. i guess thats asking a bit.
Old Apr 3, 2013 | 01:40 PM
203Cree's Avatar
Yep, that one goes to the aux air valve.
As far as timing, I just went off idle quality and throttle response.
Old Apr 3, 2013 | 04:42 PM
yodafan93's Avatar
dude youre my hero. thanks a bunch. now does your hose taper?
Old Apr 5, 2013 | 06:43 AM
WD_40's Avatar
No taper to that hose - same diameter from under throttle body to front of IAV.
There's also an air hose that comes off the back of the IAV. It loops under and around and attaches on the side of the air plenum next to the cold start injector.
Old Apr 5, 2013 | 07:14 AM
yodafan93's Avatar
already got that hose. the guy before me lost this hose, and jerry rigged it by sticking 2 hoses together with rtv.
Old Apr 5, 2013 | 07:25 AM
WD_40's Avatar
Have you gotten a replacement hose yet? Reason I ask, I need to replace those hoses on my engine. Just wondering if you were able to get them at the local parts store or had to order from the stealership.
Old Apr 5, 2013 | 07:40 AM
yodafan93's Avatar
had to get that hose at a dealership. 25$ but alot of the other vacuum line the dealer just took me in the back, cut me 6 ft or so of line, and didnt charge me anything. I cant really call them a stealership lol.
Old Apr 5, 2013 | 07:41 AM
yodafan93's Avatar
they charged me for this one cause they had to order it.
Old Apr 5, 2013 | 08:24 AM
WD_40's Avatar
Makes sense. And since it's a molded line you can't just use a generic hose from Vatozone.
zd92655
Mar 6, 2022 12:58 PM
JF9243176
Oct 8, 2017 04:21 AM
marcusSRG
Jun 27, 2015 07:13 AM
JF9243176
Jun 24, 2015 04:53 AM
saphirekosmos
Jun 22, 2015 10:26 AM
