trail gear hysteer install
Old Mar 26, 2010 | 08:48 PM
jesse j's Avatar
just woundering if any one has install picks on the ifs box on an solid front axle,im interestedin the placement of the box ,i also would like some feed back on the trailgear products thanks alot
Old Mar 26, 2010 | 09:42 PM
dropzone's Avatar
Fossilized
I am running T-G High Steer on my truck, upgrade the studs to ARP (cheap insurance IMO) It works great. I would just recommend keeping an eye on the tie rod ends...mine are fine but they have a reputation for wearing quick...not every one has that type of experience though.
for steering box mountings I wish i has seen this prior to doing mine
it is a pretty good example
Originally Posted by waskillywabbit
The IFS box mount is pretty simple. Cut the fender well so you can easily access the PS box area like shown in my pictures posted already and then push the box all the way forward until it is on the core. Angle it so the holes line up on the frame in the center and then test fit your mounting plates. Tack weld and test fit again to make sure the pitman arm clears and weld out.
before your final welds cycle the steering-->what you don't want to have happen when you install your high steer:
Originally Posted by 98taco4x
oh and make sure that your drag link clears your tierod.
Cause you don't want this.
Old Mar 27, 2010 | 10:59 AM
laskt9's Avatar
not to hijack but do you have to drill holes in the frame?
Old Mar 27, 2010 | 11:05 AM
4Crawler's Avatar
Yep, you need to mark, drill, and sleeve the holes and adding plating inside and out is recommended.
Old Mar 27, 2010 | 11:42 AM
laskt9's Avatar
alright cool thanks
Old Apr 4, 2010 | 06:17 PM
jesse j's Avatar
Talking trail gear hysteer problem i encountered
i installed the hysteer kit it awesome work un reall but i ran into one problem. the tie rod that runs from knuckle o knuckle hit very lightly on the oil pan on my 22 re.i have a 3 inch lift so i figure 2-3 inch lift shackles will cure the problem if you have any ?ens message me
Old May 16, 2010 | 01:26 PM
SpecialScottie's Avatar
Im about to install hysteer on my runner. Do I weld the sleves into the fame and then weld the plates on? Or do the plates hold the sleves in the frame?
Does someone have a writeup?
Old May 16, 2010 | 03:42 PM
DoveGray85's Avatar
I did the Marlin Hysteer kit. With that kit, the sleeves are already welded to one of the plates. Not sure about the Trail Gear kit if that's what you have.
Old May 16, 2010 | 04:31 PM
Yeah I have the trail gear kit. Anyone have any experience with it?
Old May 16, 2010 | 04:36 PM
4Crawler's Avatar
Suppose it depends on how the sleeves and plates are made. If the sleeves stay behind the plates, then probably best to weld the sleeves into the frame and grind flush. If the sleeves stick through the plates, then they probably get welded to the plates and then the plates to the frame. Best to ask TG, though.
Old May 16, 2010 | 04:41 PM
Right on. Thanks 4crawler. The sleeves stay behind the outter plate but go through the inner plate.
Old May 16, 2010 | 04:44 PM
DoveGray85's Avatar
I take it the Trail Gear kit doesn't have the sleeves welded to one of the plates. I think you're gonna want to weld the sleeves to the plates after drilling your frame. On the outside of the frame, you'll need to grind the sleeve flush with the plate, because that's where the steering box fits.
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
deepmarsh
Aug 6, 2015 03:44 AM
v_man
Jul 23, 2015 04:01 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
