RUF need help!
Old Nov 20, 2011 | 06:26 PM
Jaden84's Avatar
RUF need help!
Okay so i have been looking and looking and i can not find what bushings to get to do my rears up front? im using 84 rear springs, the front spring eye is bigger then the rear eye, also 1 is pressed in with a sleeve that makes it take 14mm bolts. I have the stock spring hanger and when i put the spring in there its lose i bought some TG bushings and there close but to big. what does everyone do for there ruf bushings? pic or links where to buy them would be grate. does this make sense?
Old Nov 20, 2011 | 06:46 PM
peow130's Avatar
Bushing I.D. is too big for the bolt?
So.... Brass spacer between bushing and bolt?
Bushing with smaller I.D.?
Bigger bolt?
Any good spring shop can get you the bushings you need.
Old Nov 20, 2011 | 08:07 PM
Jaden84's Avatar
Pretty much im asking for a bushing that is like the normal split apart toyota bushings but that is bigger to fit in the large spring eyelet that is ussualy a pressed im bushing with a 14mm sleeved hole. so that i can put my ruf
Old Nov 20, 2011 | 08:17 PM
rattlers's Avatar
sorry I dont know your answer , but can I ask you if you had to move your front spring hanger forward or were you able to use your stock one. thanks, I hope you get that all squared away
Old Nov 20, 2011 | 08:45 PM
Jaden84's Avatar
nope, dont have to do that but u do have to get high steer, different drive shaft, and the right damn bushings which i cant find!
Old Nov 20, 2011 | 09:41 PM
Jaden84's Avatar
If you could help me that would be grate! i have built a ruf spring pack out of three 84-88 spring pack. the 84-88 springs have two different size spring eyes, the larger one is the one that needs to go in my front spring hanger but the bushing in it is pressed in and has a sleeve that is for 14mm bolts, i took out the sleeve and then could put the 18mm bolt through but now my problem is there is about a 1/8 inch gap on each side of the spring between the hanger so if i had some normal toyota bushings that have that 1/8 wall that would solve my problem but they are to small since this is the large end that was intended for the pressed in bushing what did you do about this what bushings do i need? thanks, Jaden
Old Nov 21, 2011 | 02:56 AM
rokblok's Avatar
I think I am understanding your question, can you put some large diameter fender washers to take up that gap between spring and hanger?
Old Nov 21, 2011 | 05:59 AM
Jaden84's Avatar
Yes that could work, but I figured that there was a bushing that would make it right. If nothing else thais what I will do. Just wish I could do it right with a bushing though.
Old Nov 21, 2011 | 08:16 AM
4Crawler's Avatar
You can get the 40mm bushing with or w/o the sleeve to fit the larger spring eye. There are 30mm and 40mm ID spring eyes:
- http://www.4crawler.com/4x4/ForSale/...l#PolyBushings
If using the stock front hanger with the funky OEM spring hanger pin,
you could also cut those off and weld on hangers set up for whatever size bolt you want:
- http://www.4crawler.com/4x4/CheapTri...ringHangerDrop
Or you could get an '83 or earlier main leaf as they have the 30mm ID springs eyes like the stock front springs. Benefit there is you can run the stock front spring pin and the bushing lips are the full thickness.
Old Nov 21, 2011 | 09:00 AM
Jaden84's Avatar
[QUOTE=4Crawler;51823248]You can get the 40mm bushing with or w/o the sleeve to fit the larger spring eye. There are 30mm and 40mm ID spring eyes:
If I got the 40mm bushings from here, would there be the 1/8inch gap on each side of the sring and the hanger walls? Thats what I get if I try using the stock 40mm pressed in bushing
Old Nov 21, 2011 | 09:05 AM
4Crawler's Avatar
The 40's tend to have thinner lips than the 30s, but no issue putting in a thin washer on each side. I've run washers on my front hangers for at least 12 years. I built the hangers extra wide in case I wanted to run wider springs, like the 2.5" wide Rancho 44044 or something similar. I just insert a 3/4" flat washer on each side of the bushing as I slide in the bolt to keep it all centered.
Old Nov 21, 2011 | 09:09 AM
peow130's Avatar
i literally gave you 3 VERY viable options to solve this problem....
jeez..
Old Nov 21, 2011 | 11:17 AM
Jaden84's Avatar
jeez..
Well im not talking about bolt size being wrong, but thanks.
Old Nov 21, 2011 | 07:32 PM
runs-on-4's Avatar
justdifferentials
14
Jun 11, 2017 08:36 PM
live4soccer7
May 11, 2016 06:52 PM
I8URSVT
Jan 15, 2016 07:25 PM
Toys4parts
Sep 26, 2015 01:56 PM
I8URSVT
Sep 3, 2015 11:42 AM
