rears up front
rears up front
did the rears up front and i got some major axle dive goin on. when it starts humpin stuff out on the trails it gets pretty bad... what could i do to solve this issue? i think i'm gonna crack some leafs if this keeps up
http://www.4crawler.com/4x4/4R_suspe...l#Update-part2
when i hit the brakes the axle pivots forward, 3rd goes up in the air, same as axle wrap
thats exactly what i'm looking for thanks!
Assuming you are talking about axle wrap or wheel hop, I added an anti-wrap leaf to the top of my rear spring pack up front. Basically a half leaf, arched more than the rest of the pack with a clamp underneath the rest of the springs that it can pull up against to resist the torque of the axle on the springs:
If you keep the stock push-pull steering, you keep the torque rod. If you convert to crossover steering, you need to remove the torque rod to fit the steering components installed. But yes, w/o a torque rod, you can get more wheel hop, although the way the factory torque rod is set up, it won't totally control axle wrap since the axle end of that rod really needs to be triangulated with two mounts on the axle.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
jerusry
Oct 19, 2015 05:28 PM
toyoda8488
Jul 5, 2015 10:18 PM
