rears up front
Old Jan 18, 2009 | 11:14 PM
algranger's Avatar
rears up front
did the rears up front and i got some major axle dive goin on. when it starts humpin stuff out on the trails it gets pretty bad... what could i do to solve this issue? i think i'm gonna crack some leafs if this keeps up
Old Jan 19, 2009 | 09:20 AM
algranger's Avatar
bump. anyone?
Old Jan 19, 2009 | 10:19 AM
WFO's Avatar
WFO
Im not sure what you mean by axle dive
Old Jan 19, 2009 | 10:27 AM
4Crawler's Avatar
Assuming you are talking about axle wrap or wheel hop, I added an anti-wrap leaf to the top of my rear spring pack up front. Basically a half leaf, arched more than the rest of the pack with a clamp underneath the rest of the springs that it can pull up against to resist the torque of the axle on the springs:
http://www.4crawler.com/4x4/4R_suspe...l#Update-part2
Old Jan 19, 2009 | 10:54 AM
algranger's Avatar
when i hit the brakes the axle pivots forward, 3rd goes up in the air, same as axle wrap
thats exactly what i'm looking for thanks!
Old Jan 19, 2009 | 11:25 AM
WFO's Avatar
WFO
Mine does it too. I really notice it in reverse, if you slam on the brakes the front end shoots up. Never been bad enough to worry about though.
Old Jan 19, 2009 | 12:33 PM
Wardamneagle's Avatar
I assume all you guys with this issue removed your torque rods? I put the OME 2 1/2" lift kit on all around but I left my torque rod connected in the front.
Old Jan 19, 2009 | 01:09 PM
4Crawler's Avatar
If you keep the stock push-pull steering, you keep the torque rod. If you convert to crossover steering, you need to remove the torque rod to fit the steering components installed. But yes, w/o a torque rod, you can get more wheel hop, although the way the factory torque rod is set up, it won't totally control axle wrap since the axle end of that rod really needs to be triangulated with two mounts on the axle.
Old Jan 19, 2009 | 03:01 PM
algranger's Avatar
yeah i'm fixin to do crossover, was just talkin to a guy a few mins ago about an ifs steering box so no torque rod for me.
88sasturbotoy
Jan 30, 2026 01:57 PM
lledwod
Aug 30, 2016 01:03 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
toyoda8488
Jul 5, 2015 10:18 PM
