Project daily driver 85 4runner
Old Jan 19, 2019 | 04:46 PM
NYHumpinUtah's Avatar
Yes, She sure does
When's your next trip north, I hope after the snow melts!
Old Jan 19, 2019 | 05:01 PM
Damion812's Avatar
5 Year Member
Originally Posted by NYHumpinUtah
Brent, Welcome to the 84-85 forums us guys gotta stick together She'll be looking fine in no time:
tks for the reply, I actually was planning on going to look at an 84 if we didn't get this one. Complete with them 80s stripes! No need for it to be perfect yet. Driver first , then maybe total restore over the long run. I was just messing around with some parts I had left over from other Toyota trucks. I was interested in seeing how locked on them lug nuts were. I plan on going through the brakes here soon. I've got new calipers for the front and wheel cylinders for the back. The PO said all brakes were replaced recently and the front pads look like they have a lot of meat on them. The rotors look good. The rears I need to take the drums off and have a look. The e brake works and the cables are new but they get stuck so I want to get that apart the free it all up. The welding that is top priority to stop the rain from getting in. Other than the inner front quarter panels it has typical stuff but not horrible.
Old Jan 19, 2019 | 05:02 PM
Damion812's Avatar
5 Year Member
LOL! Not very pretty but she took me to pretty places.
Like this after we met...
TENTS ARE OVER-RATED
wow ! Thats gorgeous. Where is it out west?
Old Jan 19, 2019 | 05:09 PM
Utah
My home sweet home
Ray stopped by to say hello on his way there.
Old Jan 19, 2019 | 05:10 PM
  #25
Damion812's Avatar
5 Year Member
Utah
My home sweet home
lol, saw that in ur screen name. Cool photo tho
Old Jan 20, 2019 | 04:57 AM
  #26
Damion812's Avatar
5 Year Member
Happy New Year and Welcome to the forum!
Love the 1985. Just focus on getting her to be reliable; make her pretty later. Did that to my 1986, but she took me to many adventures since I got her in 2012, no time to make her pretty - LOL!
by the way RAD4runner, I came across the thread about your rig when looking at photos of the fuse panel! I like your write up on adding the buzzer for the lights. Great write up. I'm definitely going to do that. My wife left the lights on at work the other day and if course nobody could say anything. They prolly hate this ,this, thing, lol. But first off I started thinking the worst. I started pulling fuse covers checking fuses then the lights. Oh looky there somebody already turned them on, ha ha. Anyhow no biggie I have jumpers in the FJ just had to do a little 4 wheeling over the curb and into a field to get into position.
Old Jan 20, 2019 | 08:44 AM
  #27
RAD4Runner's Avatar
...buzzer for the lights. Great write up...Oh looky there somebody already turned them on, ha ha. ...
LOL! Yeah, very first mod I did.
Then I rewired the starter relay. Many fellow members have issues with the cranking system because Toyota wired it wrong AT THE FACTORY for 86 and later. Then , your truck and Hump's do not have the starter relay. You might want to consider adding. Pls search my thread for "clicknostart".
Utah
Yes, Refection Canyon, 2-hour drive out of Escalante. Then 8-mile one way hike. No motorized access, no helicopter tours. Only accessible on foot.
Old Jan 28, 2019 | 01:20 PM
  #28
Damion812's Avatar
5 Year Member
sounds like my kind of place!
Old Jan 28, 2019 | 01:33 PM
  #29
Damion812's Avatar
5 Year Member
So the more I thought about them wheels spacers I decided to see if they were really needed . As far as I can tell the back spacing on them wheels is sufficient to keep the tires from rubbing . Maybe at extreme angles there is a slight possibility of rubbing but I'll worry about that when the time comes . For anyone reading this and using wheel spacers and have not had any issues with them I hope it's always that way I don't think they were needed in this case. Maybe the previous set of tires hit.
on another note I started working on the brakes. I swapped the front calipers with new and it looks like they were new but really rusty. I did find one piston seized though. Probably due to sitting for a long time. It also looks like the caliper bracket part of the steering knuckle was stripped so somebody put some other bolts in. Now I'm working on fixing that when I tear the steering knuckles apart to reseal the axle. I got the kit from Marlin crawler.
next is the rear brakes . The e brake works but gets stuck. I'm also considering swapping the master cylinder with the later one they have at Marlin Crawler.
Old Feb 6, 2019 | 06:23 PM
  #30
Damion812's Avatar
5 Year Member
I replaced the rear wheel cylinders and got the E Brake working again and adjusted it also. The rear drums and shoes are new , replaced by PO. It was funny only the passenger side E Brake lever was seized. The drivers side was well greased up.
now I'm working on welding the inner quarter panels.
Old Feb 8, 2019 | 08:04 PM
  #31
Damion812's Avatar
5 Year Member
There is some great info on this forum . I found this on the thread titled my first 22re what to do
Originally Posted by Odin
Welcome to the site. That's a good looking truck.
Let me throw out some common things that will possibly prevent you from posting things that have already been covered time and time again.
First things first
Before any work is done make sure there isn't currently a problem with the head gasket or changing the engine oil and filter along with any work on the cooling system will be for nothing and a waste of money.
Do a Block leak test to see if the head gasket already has any problems!
Use a Block leak tester, Combustion leak tester, Combustion leak Detector, whatever you want to call it:
The Combustion Leak Test Kit will test your coolant for the presence of exhaust gases. This proves if there is a breach between your combustion chamber and coolant passages or not.
Examples of block leak testers:
Amazon.com: UVIEW 560000 Combustion Leak Tester: Automotive Amazon.com: UVIEW 560000 Combustion Leak Tester: Automotive
Amazon.com: Lisle 75500 Combustion Leak Detector: Automotive Amazon.com: Lisle 75500 Combustion Leak Detector: Automotive
Next you'll want to follow that up with a compression test to check for a tired engine with rings that don't seal well or leaking valve problems.
If the engine was leaking coolant into the cylinders for long and they kept driving it there's a chance that some of the cylinders will not be sealing well and be down on output. Some people will not be happy and want to rebuild the engine.
If you're happy with the results change your fluids. I change the fluids even if it looks good. You never know what garbage was put in there, it might just be from the dollar store.
Oil
Oil Filter
Differentials
*Transmission
Transmission gear oil:
Most people and shops install standard GL4/GL5 gear oil in these transmissions. While that's not bad it seems these Toyota/Aisin manual transmissions really seem to love Redline MT-90 75W90 GL-4 Gear Oil http://www.redlineoil.com/product.aspx?pid=46
There are several links on this site and many others where Toyota owners swapped it and loved it. Here is just one, https://www.yotatech.com/forums/f2/m...t-90-a-211552/
A word about oil and oil filters on the 22R/RE series engines
Because of the mounting angle these engines need an oil filter with a very good anti drain-back valve. If you run them with an anti drain-back valve that's not real good it causes some start up noise. I've been through a few different brand and design oil filters https://www.yotatech.com/forums/f123...sioner-288088/
The best I've found at preventing start up noise is the OEM Toyota 90915-YZZD1.
Most long time 22R/RE owners swear that synthetic oil isn't needed on these engines as it doesn't seem to benefit them much. Alot of these engines will go for 250k-300k on standard oil with Regular Oil And Filter Change Intervals of between 3,000-3,500 miles.
It's fairly common to have a somewhat noisy valvetrain on these engines and most seem to think that synthetics (even thick ones) only make it worse.
Alot of people with fresh engines run non synthetic 10W-30. Alot of people with close to 100K run 10W-40 and then there are those who really love to run these engines with 20W-50 because it quiets the valve train down. With over 100,000 miles on my engine I'm in the 20W-50 group.
Check the fault codes!
It's a good idea to check for codes even if the Check Engine Light isn't illuminated. Sometimes the computer will have active faults but they won't trigger the CEL.
First turn the key to the run position (don't start it) and make sure the Check Engine Light comes on. If it does you're a go to start checking the codes. It's super easy and here's how
http://www.4crawler.com/4x4/CheapTricks/TroubleCodes/
Sometimes a code will be triggered by a bad ground so make sure all of the grounds are in place and they are good!
GROUND WIRES!!!
What some don't realize is that bad grounds can contribute to a failing cooling system in the form of electrolysis that I mention below so be sure they are all there and in good shape.
Here is the 22re ground wire guide.
https://www.yotatech.com/forums/f116...-guide-194413/
It's a good idea to check the grounds for other issues and prevention of mysterious problems or poor performance. Sometimes cleaning or replacing grounds can make an amazingly big difference in the overall drivability of the truck. Brighter headlights, stronger heater blower, easier starting, eliminate charging problems, smoother idle etc.
You might want to have a quick look here too
https://www.yotatech.com/forums/f127...charge-287463/
I can't begin to tell you how many people on this website overlook their ground wires!
Even if you tell them to check them out all they seem to want to do is take a quick glance at them without unbolting them to look at the actual connection. Ask them to do a voltage drop test to find a bad wire or connection problem and there's a very large chance that isn't going to happen. Electronics definitely isn't my strong suit either.
Your leaking valve cover
It's common to find that the valve cover is leaking from the rear. It's most likely not even the valve cover gasket causing problems, it's probably the rubber Semi-Circular/Half moon end plug at the back that sit's directly underneath the valve cover gasket. There's one at the front of the head and one at the back. Not many report a problem with the front one but the back one has a bad reputation especially when the valve cover has been removed to check the valves and then reinstalled. You'll want to fix that asap because even a small leak can create one heck of a mess on top of the transmission and under the truck if you let it go for long enough. Mine had been leaking for so long before I purchased it that I'm pretty sure it saturated the clutch disk. I was getting stinky clutch slip when I'd give it full throttle at low rpm in third. When I fixed the leak the clutch started slipping less and less.
It's generally recommended that you go with the Toyota OEM Valve Cover Gasket PN# 11213-35010
The Felpro Semi-Circular/Half moon plug is slightly thicker and probably stands a better chance of sealing up but some people still prefer to use OEM parts.
Toyota Semi-Circular/Half moon plug PN# 11183-38010
Felpro Semi-Circular/Half moon plug PN# CP75005
Look at this link for valve cover replacement procedure http://personal.utulsa.edu/~nathan-b.../7cylinder.pdf
Scroll down to page EG1–35 and have a look at Fig 7. and also Fig 8. on page EG1–36.
Right under that is the torque specifications for the valve cover.
If you don't have a torque wrench run the nuts down till seated and turn them another 3/4 of a turn.
Use Toyota FIPG or Permatex Ultra Greysealant in the area's indicated.
I had a very small leak back there and found running my hand on the back of the engine wasn't a good way of looking to see EXactly where it was coming from. I purchased a curved dental inspection mirror and used it along with a flashlight to see the leak. It worked good enough that I could see where it was coming from but I found the viewing area of the mirror to be a little small and the fact that I couldn't bend it to get the angle I wanted was very frustrating.
I was loaned this tool and it works very well for this purpose
Amazon.com: Ullman HTE-2 Glass High-Tech Telescoping Inspection Mirror, 1-1/4 Amazon.com: Ullman HTE-2 Glass High-Tech Telescoping Inspection Mirror, 1-1/4" Diameter, 6-1/2" to 35" Extended Handle Length, Clear: Industrial & Scientific
Since you'll have the valve cover off fixing a leak it's a great time to check the valve lash and have a look at the timing chain guides
The Factory Service Manual calls for a valve lash of .008 Intake & .012 exhaust (Inches) Warm.
After some people set them to factory specifications they find the valves make too much noise. What usually quiets them down is setting them to .007 Intake & .011 (Inches) Exhaust Warm.
Here's how to set the valves http://www.lcengineering.com/LCTechP...djustment.html
What you're trying to do here is make sure the rocker is on the base circle/heel portion (no lift portion) of the cam so that the valve is in the fully closed position. It's very easy to see when you look at the cam with the valve cover off.
Timing chain guides
YOU DO NOT WANT TO OVERLOOK THIS AREA!
COOLING SYSTEM
22RE Temperature overshoot.. What is it?
Question: “Why does my engine temp go all the way up to the red before it comes back down to the middle of the gauge after I start it up in the morning. It only does this when the engine is cold and once it warms up it seems to operate normally. Could it be as simple as a stuck thermostat?”
“What happens on the 22R and 22RE engine, when the coolant goes through the heater core it gets cooled off enough that when it gets dumped back in on top of the t-stat it shuts it. Therefore the temperature in the engine continues to go up. The Toyota two stage thermostat has two valves in it, one opens at the regular temp, and one smaller that opens at a cooler temp. If the cool water shuts the big one, the smaller one stays open. All this happens because of the lack of a by-pass hose, which on other systems, keeps hot coolant running on the t-stat.”
You can get the two-stage thermostat mentioned above from your local Toyota Dealer but it isn't cheap. It is also a 190 degree thermostat.
Toyota Two Stage 190 degree thermostat P/N: 90916-03070
Also, sure you can get an aftermarket thermostat and perhaps never have a problem with it sticking open or closed but it seems that is an incredibly shrinking list. You sure as hell don't want a thermostat to stick closed on one of these engines!
If you want a cooler 180 thermostat there is always the OEM Toyota 180 degree thermostat made by Kuzeh. It might still cause the temperature overshoot but it will run at cooler temperatures.
Toyota one stage (normal) 180 degreethermostat
Toyota P/N: 90916-03083
Cooling system maintenance, YOU DON'T WANT TO OVERLOOK THIS AREA
Because of dissimilar metals (iron block and aluminum head) these engines are susceptible to electrolysis in the cooling system. What it basically means is that the coolant turns acidic and starts eating components.
I suggest you take a look at the coolant that's in the overflow bottle. If it's green you'll want to replace it with OEM Toyota Red P/N: 002721LLAC01 (it's not cheap) and DISTILLED WATER. That coolant is a special low silicate formula that helps prevent electrolysis from starting on Japanese engines with dissimilar metals. You'll still need to flush and replace on a regular schedule.
"When the coolant gets acidic it will act like an electrolyte, this sets the stage for electrolysis to occur and the destruction of thin aluminum components to begin."
"Electrolysis occurs when stray negatively charged ions (electrical current) routes itself through the engine coolant. The electricity is attempting to find the shortest path, and impurities in the coolant often generate a path of least resistance that the electricity travels across. The source of this stray electricity is often from electrical engine accessories which have not been properly grounded. A missing engine or transmission ground strap can also cause the coolant to become electrified. Sometimes the path of least resistance becomes a radiator, a heater hose, or even the heater core. These components are often well grounded, and offer a ground path from the engine to the chassis by means of the semi-conductive path of the coolant.
Electrolysis can destroy your engine quickly. Although it’s semi-normal to have very small amounts of voltage potential in your coolant system, values greater than about a tenth of a volt can start reactions between the coolant and the metal in your engine. In particular, electrolysis affects primarily aluminum engine components, resulting in pitting and scaring of the aluminum surface. This eating away of the metal can cause coolant system leaks, and in particular, radiator leaks around aluminum weld. Aluminum components are always most vulnerable. On Aluminum engine blocks and heads in particular, electrolysis can be easily seen attacking aluminum. Figure 1 shows a picture of the thermostat area of a cylinder head that has been partially damaged by electrolysis. Notice how the aluminum has been eaten away, and eroded by the chemical/electrical reactions."
From the ASE page
"Electrolysis is extremely corrosive and eats away the inside lining of aluminum parts, especially thinner parts like aluminum heater cores. It is said that a current of 0.5V or more will corrode a cast iron block. It takes much less current to damage an aluminum engine block and many of its components. It's more like 0.15V to 0.20V."
Testing for electrolysis is incredibly easy but is often overlooked
More testing information at
http://www.sancarlosradiator.com/Vol...ectrolysis.htm
The Tune up
Use only standard spark plugs. No need for ultra expensive plugs with 12 ground electrodes or exotic materials.
Thinking about installing US plugs like AC Delco, Autolite, Champion..
DON'T, just don't do it.
The best thing you can do is go to the dealership and get the OEM Denso spark plugs.
Toyota P/N: 90919-01064
Believe it or not they are different than what Denso sells to the aftermarket. The aftermarket Denso plugs have a screw on terminal tip that can come loose and cause mysterious engine roughness.
Second in line would be off the shelf NGK V Power spark plugs
P/N: BPR5EY (Stock#1233)
Distributor cap and rotor
I can't single out one brand out but I know there are many on this website that from experience once again recommend you use only the dealer service center available Denso cap and rotor.
About spark plug wires,
Yes you can get a set that transfer slightly more current than the OEM wires but you won't be gaining anything noticeable over a GOOD (not toasted and used up) set of OEM plug wires. You simply won't be gaining much if anything here. Because of this I consider the OEM dealer service center replacement wires a better choice because of longevity and fitment.
OEM wires are the perfect length and they come with all the correct looms that bolt to your valve covers helping to keep the wires in place and routed neatly.
Most aftermarket wires are too long and look sloppy when mounted.
A couple other things the OEM wires have going for them over an aftermarket set is that they are also sealed wherever the boot meets the wire helping to keep out moisture. That's something none of the aftermarket wires have.
Also all of the aftermarket wires I've seen have fitment issues in my mind.
For the most reliable fitment and connection Angled spark wire boots get Angled connectors and Straight boots get Straight connectors!
The OEM wires have angled connectors and boots like it should be.
What does the aftermarket set have.. Angled boots and Straight connectors...
OEM wires and looms
If you're heart is set on aftermarket I'd get NGK's or Belden Premium from NAPA, most others are just hyped up junk or overpriced for this application.
Clutch Hydraulics
If you need to replace the clutch master or slave cylinder do not purchase these from your local parts store- AutoZone, O'Reilley etc. Don't let the lifetime warranty suck you in. There are MANY posts about out of the box failures and short life spans with the standard auto parts store replacement parts.
Replace these parts with Aisin parts. You can use http://www.aisinaftermarket.com/English/Catalog.php to find what you need then check the internet for the best prices. Be sure to check Rockauto.com for prices (don't forget to add the shipping price to the total) and do a search on the part number. The price for Aisin parts isn't much more than the junk you'll get from your standard parts store.
If you're going to replace the clutch master and slave cylinders you should go ahead and replace the clutch hose at the same time.
With age the hose can weaken and balloon when you push the pedal resulting in a loss of pressure and a loss of movement.
Clutch bracket cracks
It's common for these trucks to develop cracks in the clutch bracket that will prevent full operation of the clutches hydraulic system making it difficult to shift. Crawl under there with a flashlight and depress the pedal. Look for any bracket movement, flex, or cracks. If any are detected you'll need to remove the bracket and have it welded.
Shifter
It's common for the rubber shifter seat bushing to get mashed and start falling apart resulting in sloppy, imprecise shifts.
A FANTASTIC remedy to this is the Delrin shifter seat and socket upgrade available from https://www.marlincrawler.com/hardwa...-forward-shift
I like it so much I recommend everyone get the set even if they don't have sloppy shifter problems.
Headlights
A common failure is that the high beams quit working, there's a common fix for that too. It's usually a dimmer switch/headlight combo switch problem https://www.yotatech.com/forums/f131...h-beam-156395/
Most people say these trucks have dimm headlights, there's a reason for that.
Because of the thin wires Toyota used and the way they are routed there simply isn't enough voltage making it too them so they're dimmer than average. It's highly recommended that you either purchase or make a headlight relay harness. If you have the 9004 headlight you might be better off making one.
Have a look in this section for most of your electrical and headlight problems
https://www.yotatech.com/forums/f131/
this is also part of my list plus the things I've found so far.
Old Feb 10, 2019 | 08:26 AM
  #32
Damion812's Avatar
5 Year Member
A buddy of mine gave me some stuff he got from a past Toyota mechanic ...😁
Old Feb 10, 2019 | 09:28 AM
  #33
old87yota's Avatar
That is pretty neat!
Old Feb 11, 2019 | 02:34 PM
  #34
Damion812's Avatar
5 Year Member
couldn't beat the price eather! Funny thing too on the way home from getting these we spotted a tan first gen 4runner in Windsor Locks. I rarely see em out and about. Almost stopped to check it out and see if they wanted a set of plugs.
Old Feb 11, 2019 | 02:45 PM
  #35
Damion812's Avatar
5 Year Member
Disclaimer: I don't build them for a living just for fun and I should in no way be considered an expert mechanic or body guy what so ever (or a professional writer also). isclaimer:
Anyhow here is some of the cancer so far. It was all fun and games welding until the brand new welding helmet got funky on me today in the middle of welding then seeing spots was fun. Probably be returning it tomorrow. Between welds I took out the rotted muffler and tail pipe and replacing it . I found the brand new muffler leaking right down the seam. Ugh I know these are cheap from a certain ROCK place for AUTO but the others I've gotten worked ok. I could send it back and they are no problem with returns but then I would have to wrestle it out of there probably mangling the remaining exhaust pipes. Ahh ya win some and ya loose some I guess.
Old Feb 12, 2019 | 08:39 AM
  #36
Damion812's Avatar
5 Year Member
a few shots of fixing the cancer. I'm thinking on the drivers side I'll do this a little bit differently.
swapped the welding helmet . I should of known something was up when I wasn't the person to add the batteries. It must have been opened before Ibought it. That and no owner's manual with the first one.
Old Feb 12, 2019 | 08:40 AM
  #37
Damion812's Avatar
5 Year Member
Old Feb 12, 2019 | 08:43 AM
  #38
SomedayJ's Avatar
Looking good!
Old Feb 12, 2019 | 12:24 PM
  #39
RAD4Runner's Avatar
Originally Posted by SomedayJ
Looking good!
Second that!
Old Feb 13, 2019 | 07:19 AM
  #40
Fahkncj's Avatar
Body work...I been trying to get better at it, looks great!
