No rear heat.
Old Oct 26, 2007 | 11:42 AM
tibbycruiser's Avatar
No rear heat.
I have an 88 4runner with the 3.0 v6, recently I replaced the fan idler and flushed and filled the Radiator with fresh coolant, I also added a new T-stat
(180). The front heater is getting warm but when I turn on the rear heat, center console, it wont get warm, just blows cold air.
Its starting to get cold here in CO and i want to get the rear heat working asap.
Is there an easy fix for this or not easy fix?
Thanks
Old Oct 26, 2007 | 11:49 AM
I think i posted in the wrong section.
Mod can you please move this to the correct section.
sorry
Old Oct 26, 2007 | 12:22 PM
4Crawler's Avatar
1. Make sure the rear heater hoses are connected, perhaps a previous owner bypassed it.
2. Make sure the heater valve is opening. If unsure, pull the heater out and examine the valve internally.
3. Make sure the rear heater core is not clogged. Try backflushing it with clean water and make sure it flows well.
Old Oct 26, 2007 | 12:35 PM
Will do ,
Thanks
okamikai
Apr 30, 2018 10:19 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
jjrbus
Jul 19, 2015 02:06 PM
icentropy
Jul 14, 2015 10:23 AM
