My head questions
Old May 1, 2018 | 04:16 PM
NYHumpinUtah's Avatar
My head questions
Hi all
Just had my head rebuilt and, well I'm not very happy with the work the guy did. To start with the guy has "0" personality and I mean 0 so after I had talked to his brother about doing the block (he's ok) he introduced me to his brother the 0 guy. So when I got it back I really didn't want to get into it with him, I still might go back and give me my two cents.
Anyway, I have a question about the head on the exhaust side. You have those 4 tubes on top of the exhaust ports, I'm not sure what they are called but I believe they have something to do with emissions, the ones you end up blocking off. Looking inside the head in those 4 tubes, 3 of them are broken and 1 is I guess long the way they used to be (see pics)
Can i and how do I remove them? It seems to me that these tubes would hinder the flow of the exhaust
I should mention this is a 20R head
Advice
Thanks
Old May 2, 2018 | 06:00 AM
se7enine's Avatar
I would just drill them out. They should be removed or plugged if blocking anyways. Also I'm surprised it didn't come back cleaner like this.
Old May 2, 2018 | 06:11 AM
SENOR NOODLES's Avatar
I do not think I have ever actually seen those in place.....
Drill the top flares off and pull them through, Or mini air saw, cut the end inside of the exhaust port and pull them out.
They are for the air injection. I do not know why they go so far in, when they are supposed to be helping the cat.
Old May 2, 2018 | 08:42 AM
They are for the air injection. I do not know why they go so far in, when they are supposed to be helping the cat.[/QUOTE]
Yeah, I don"t know and don't know why they look like they were blown up at the ends? Very strange, like a lot of other things on this truck.........
Old May 2, 2018 | 08:47 AM
Ahh, I could almost smell that blue dykem............... brings back the past when we used layout line to tell us where to make the cut. Back in the 60s , was the only way till NC took over then CNC.........lost art
Old May 2, 2018 | 06:48 PM
Here are pics of the combustion chambers, the guy who rebuilt it said there were some nicks in it so he did a little grinding! Guess I have some polishing to do............
Old May 3, 2018 | 04:41 PM
Ok, All drilled out, what a pia, these tubes are hard. Had to use 4 different sizes drills to sneak up on it., finally got to where I could pull them out. I also went ahead and taped them for 1/8 pipe so I could put plugs in them
It's all good
Old May 3, 2018 | 06:42 PM
RAD4Runner's Avatar
That's hardcore work! Best of luck.
Originally Posted by NYHumpinUtah
... head Question... guy has "0" personality
I thought someone needed a shrink - LOL!
Old May 3, 2018 | 07:52 PM
I will after I get done with this build!
shifty
Nov 14, 2007 03:54 PM
imtxn
Dec 11, 2006 07:30 AM
StevenR
Jun 14, 2005 09:49 AM
The Rusty Gear
14
Sep 13, 2004 07:03 AM
