lower kknuckle cap wont fit on 6 stud knuckles HELP!?
Old Dec 16, 2011 | 02:32 PM
LGs_Woody's Avatar
Exclamation lower kknuckle cap wont fit on 6 stud knuckles HELP!?
alright i bought the 6 shooter knuckles and jy steer from my buddy. today ive been workin on rebuilding the axle. ive got to the part where i have to put the lower knuckle cap on the knuckle and the stock lower knuckle cap wont slide into the new 6 shooter knuckle. ive tried searching and i cant find anything that helps. what am i doing wrong??
Old Dec 16, 2011 | 02:33 PM
LGs_Woody's Avatar
do i need to buy after market lower knuckle caps?
Old Dec 16, 2011 | 03:51 PM
rokblok's Avatar
If you ordered six shooter knuckles, I believe they use the stock lower bearings, caps and shims. Does it go on the studs at all? Or is it just not fully seating? If thats the case, its not lined up properly and is not going into the center race of the lower bearing. I had this problem when I rebuilt my knuckles. A bit of wiggling everything and it went together.
You may want to verify that the cap is going into the bearing. Do this when the parts are in your hand, not on the truck...
waskillywabbit's Avatar
No. Emory cloth and sand them down a bit as they fit into the bearing not the knuckle per say.
:wabbit2:
Old Dec 16, 2011 | 05:01 PM
LGs_Woody's Avatar
:wabbit2:
It slides on the studs but the first "nipple" wont slide in the hole on the knuckle. The bearing slides over the "smaller nipple". I even took the knuckle off the truck and turned it over and tried beatin the bearing cap in but it just wont fit. In other words, the hole on the knuckle is too small.
Old Dec 16, 2011 | 05:12 PM
rokblok's Avatar
So if you flip the knuckle over, and with no bearing, the cap wont fit into just the knuckle? Can you see any "interference" where the cap slides in? Since you were beating on it, did it possibly "bugger" the knuckle or the cap where they meet? Or if you hold the cap up to the knuckle, can you see that it is way off alignment?
Old Dec 16, 2011 | 05:23 PM
4Crawler's Avatar
Might just need a little filing or sanding to clean up the fit. Run a file lightly around the edge of the cap stud and some emery cloth or metal sandpaper around the inside of the hole in the knuckle to clean it up a bit. And try a felt pen to blacken the end of the cap and try to insert it and pull it out to see where the black is rubbed off and that will be the high spot. Prior to installing it, clean both parts well and lightly oil or grease to let it slip in easier:
- http://www.4crawler.com/4x4/CheapTri...ckleBearingFit
Old Dec 16, 2011 | 09:14 PM
LGs_Woody's Avatar
Its not that, the hole in the knuckle is too small.
Old Dec 16, 2011 | 09:20 PM
4Crawler's Avatar
Yes I know there are two pins, the small one in the bearing and the large one in the knuckle, but it is still usually a simple matter of either enlarging the hole or shrinking the pin. But how much too small are you talking about? Like 0.0001" or 0.1", it makes a big difference. With steel 0.001" difference in size can make the difference of a press fit or a slip fit.
Or call up Trail Gear and get a part that fits.
Old Dec 16, 2011 | 09:22 PM
LGs_Woody's Avatar
Is it alright if i just take a die grinder and enlarge the hole?
Old Dec 16, 2011 | 09:33 PM
scuba's Avatar
I would file the cap pin before messing with the hole in the knuckle.
Old Dec 17, 2011 | 05:32 AM
Post some pictures.
:wabbit2:
Old Dec 26, 2011 | 06:13 AM
LGs_Woody's Avatar
Alright just to update. I tried using emory cloth but it wouldnt take enough off so i got a big ole "honing" bit and slowly made the hole bigger until the caps fit in correctly. Now im on to shimming the knuckles. I hate that this is my first time doin this!
glowz825
Jan 25, 2022 09:28 AM
msane99
Jul 27, 2015 06:14 PM
msane99
Jul 11, 2015 08:08 PM
horunner1x
Jul 10, 2015 06:33 AM
mickyd9990
Jul 6, 2015 09:01 AM
