Home made turbo set up 22r
Got me a t3 turbo an some how stumbled across a sweet turbo manifold with down pipe off craigs list. I Got a holly 500 carb and built me a homemade dapater for it which isn't working btw just ordered the correct part and also orderd me a boost refranced fuel reg and made my own carb hat and I was able to hit 5 pounds but the the fuel cuts out but I'll post some pics
it is running terrible due to the carb issue i might have to get it tuned i cant seem to get the idle down low and also i hit 8 pounds today and smoked the clutch it pretty much dosnt go anywhere if ur in 4 gear it just slips thing is a beast under boost but i already have a stage 3 clutch on its way
Let me put it this way the truck would cruise down the highway at 80 mph no prob and I go my gps to 103 lol but now with the turbo it's nothing to do 100 with out mashing the gas and it's got enough power to spin the stock clutch when it hits like 5500 rpm so ya it's faster and I noticed a lot more pep on the low end with that carb and people say they are gutless but not mine and mine even runs like ˟˟˟˟ I'm running jet size 74
ok not going to lie that is awesome however the turbo sits very close to the master which could pose problems down the line could probably shorten the runners or the pipe that runs straight up to the mounting flange but its up to you
hows your mpgs with that setup
Well I thought about Doing that but I think I'm gonna make heat shields for stuff and the mpg are good if u don't run it if u do then well u will see the gauge drop lol the holly 500 is a stock car carb it's not forgiving lol
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
