Home made turbo set up 22r
Old Dec 22, 2012 | 04:10 PM
  #101
Rollz79's Avatar
Originally Posted by toyotahonda
if the 22r doesnt make enough power i made a bellhousing that bolts a toyota tranny to a k series the skys the limit with that lol
Don't waste the time on the 22R. I want to see a Kswap. If i kill the 22r im rebuilding I plan on doing B series swap. K swap FTW
Old Dec 22, 2012 | 04:41 PM
  #102
85toy4runner's Avatar
who thought a 22r series engine could become a mini monster.. just out of curiosity what would that cost me to build my 22re like that one in my 85 4runner
Old Dec 22, 2012 | 04:46 PM
  #103
rokblok's Avatar
You better figure out where to get yourself a Supra tranny..... Everything else is just going to grenade behind that engine.... Keep that camera handy!!
Old Dec 22, 2012 | 05:26 PM
  #104
toyotahonda's Avatar
I got one was going to do a divorced t case
Old Dec 22, 2012 | 07:20 PM
  #105
I got some tricks I have learned from my Hondas I will do to the Toyota tranny to help it chronic freezing the gears is cheap and helps a lot
Old Dec 25, 2012 | 06:56 AM
  #106
sjyota's Avatar
Ya so I bumped my boost up to 8 psi and have been running it super hard and today it got a loud knocking noise comming from somewhere it still runs good and it's only at certain rpm and at hight rpm ita loud I herd of the calves making this noise what u all think
Old Dec 25, 2012 | 07:14 AM
  #107
rokblok's Avatar
Yeah my cattle are always knocking.
I'm sure most of y'all won't get it...
Old Dec 25, 2012 | 11:39 AM
  #108
se7enine's Avatar
I really like the build, wish I had more time and money to put a faster engine in my
4runner. Lucky for me I have my Galant VR4 to tie up my wallet and satisfy my need for speed. Keep up the good work.
Old Dec 25, 2012 | 12:56 PM
  #109
sjyota's Avatar
This Is about to become a full motor build with 20r head and turbo pistons and everything soon just found a guy with all the parts for cheep
Old Dec 25, 2012 | 02:23 PM
  #110
se7enine's Avatar
Utters?
Old Dec 25, 2012 | 07:01 PM
  #111
Ya I wanna see what this lc stage 5 head does if I don't like it going to pull every trick known to man on a 20r head on a turbo motor your framing air down its throat so it will go
Old Dec 27, 2012 | 03:58 PM
  #112
getting her dialed in lol
Old Dec 27, 2012 | 05:21 PM
  #113
Mr_Random's Avatar
I'm interested in the Honda dizzy/ecu tuning... I want to turbo my truck before long, and after adapting the 22re system to my 84, I have noticed how limited it is on fuel and spark control. It has a knock sensor, so that, a home-made piggy-back, and wideband o2 might do some work, but it will never compare to a hondata system (which are crazy plentiful used down here near mexico ).
Combining my experience with the 22RE system and the Jeep and Chevy EFI I have worked on, I believe I could wire up a EFI harness based off a Honda system. Can the TPS and Coolant temp sensors be used? I'm assuming a wideband O2 is necessary, is it a MAP or VAF/MAF system? Knock sensor?
BTW, hope you got a new fuel pressure gauge! I had one do the same thing, had to open it up and braze/solder the copper tubing back together (the solder had a hole).
Old Dec 28, 2012 | 10:08 PM
  #114
GOT BOOST
Old Dec 28, 2012 | 10:11 PM
  #115
THAT SHOULD PUT THE FUEL TO IT
Old Dec 29, 2012 | 12:40 AM
  #116
bobcat86's Avatar
Sub'd
Old Dec 29, 2012 | 09:28 PM
  #117
CAdot's Avatar
Old Dec 30, 2012 | 10:24 PM
  #118
fully built 327 with pro injection see if it can hang with the 22r
Old Jan 26, 2013 | 04:37 PM
  #119
yota2388's Avatar
i've been trying to do this a long time ago but,i havent figure out how to make the distributor work, how did u put together the honda dizzy and the toyota one? did u weld the shafts?
Old Jan 26, 2013 | 05:56 PM
  #120
RogueYota's Avatar
Holy crap!
This has been done?!? lol
I thought about this years ago....didnt think it could be done.
Then I thought about a 4g63t from eclipses and what not.
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
cars-guy
Jul 11, 2015 07:51 PM
Poncho0206
Jul 10, 2015 06:21 PM
karbin
Jul 5, 2015 11:37 PM
