fuel pump relay
Old Apr 4, 2012 | 07:00 PM
sravbrown's Avatar
fuel pump relay
I can't find my relay on my 85 with a 22re. I've narrowed it to the relay. But I can't find it
Old Apr 4, 2012 | 07:28 PM
85toy4runner's Avatar
this might help , not sure
https://www.yotatech.com/forums/f115...-u-22re-94594/
Old Apr 5, 2012 | 08:14 PM
REVenge's Avatar
I believe the relay you're looking for is the Circuit Opening Relay which is located above the ECU, behind the passenger kick panel. Pull the speaker cover and remove the speaker and you should see it to the right.
For some reason this relay isn't shown in the FSM relay location diagrams...
Old Apr 5, 2012 | 08:21 PM
sravbrown's Avatar
So if its going out would you think it would cause the truck to sparitcally lose power and otherwise run fine?
Old Apr 5, 2012 | 08:38 PM
REVenge's Avatar
Not too sure to be honest. I'm having a fuel issue (I think) too where after about 15mins of driving the truck will start to buck, hesitate and sputter pretty bad. I have checked quite a few things and still haven't fixed my issue.
One thing I did do to try and fix my issue was take apart that relay I mentioned and clean the contacts inside. You can try that and see if it helps. I cleaned the contacts in the relay, cleaned all 4 engine bay grounds, changed plugs, cap/rotor and the truck ran fine for a little over a week but now the problem just returned today after I filled up with gas after work.
Old Apr 5, 2012 | 08:44 PM
RAD4Runner's Avatar
If you mean the circuit opening relay, it is behind the glove compartment, to the right of the blower. Here are pictures of it barely visible with glove compartment door removed. This is the relay that you hear click when you put ignition key in "Start" position.
I have started posting pics of locations of components here. I hope this would help my fellow owners of First-Gen 4Runners.
Old Apr 5, 2012 | 08:47 PM
REVenge's Avatar
Great pic RAD ^
You should put that link in your signature too.
Old Apr 5, 2012 | 09:03 PM
sravbrown's Avatar
Thanks the pic really helps and im not getting the click so I think that maybe my prblem
Old Apr 5, 2012 | 10:15 PM
RAD4Runner's Avatar
Originally Posted by REVenge
Great pic RAD ^
Glad to be of help, guys.
Tnx, REVenge. You read my mind Hope to contribute/give back to this forum that I keep on learning from. Got my Runner in decent shape, so not sure if I should call my project a Build-up of just a "Refurb"
Cheers!
Old Apr 6, 2012 | 08:01 AM
4Crawler's Avatar
You can give the fuel pump test jumper a try:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Sometimes you can't hear the COR click since the starter is making a lot of noise at the same time.
And see if there are any stored trouble codes from the engine stopping:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Feb 11, 2015 | 02:43 PM
sea dawg's Avatar
My truck's been down for the last couple months to do a RUF install and to build out the front axle. This afternoon I decided to start up the engine and see how she's doing. It would start and run for about 3 seconds and die; would not accept any gas. So I tried starting it and leaving the starter engaged after it starts and giving it gas; it ran, but didn't like it. So I tried putting in the test jumper for the fuel pump. At this point, it started and ran, but only at idle. When I tried to give it gas, it would bog down, and even backfire thru the exhaust manifold (acting like the timing had changed or something).
When I unplug the jumper, it dies immediately. So i'm guessing I need to check the relay in the AFM assembly. It sounds like I could run it with the jumper in place, as long as I don't leave it in the ON position while the engine's not running. I'm out of ideas on how to troubleshoot this. Anyone have experience with this???
Thanks
Old Feb 11, 2015 | 03:19 PM
4Crawler's Avatar
Test jumper will only run the fuel pump with the ignition is on. Check the Circuit Opening relay to see if it is getting energized by the AFM. Likely you have an air/vacuum leak in the intake plumbing:
- http://4crawler.com/4x4/CheapTricks/...shtml#AirLeaks
That will cause it to bog down/backfire/die when you hit the gas since you have unmetered air getting to the engine.
Old Feb 11, 2015 | 03:37 PM
sea dawg's Avatar
Thanks for the reply. It jogged my mind, and I had forgotten to connect the wiring onto the top of the air intake assembly!!! Fired right up. Time to adjust the new high steer, get the wheels on, and take her for a ride!!!
Old Feb 17, 2015 | 04:48 AM
sravbrown's Avatar
The Real Problem.....
So I just dove back into the site and saw this old post and thought I would share how I fixed the truck..........turns out after all that the hunting for the relay it wasn't that. the damn pump was bad and I was a lil niave thinking that if it had pressure enough to spray everywhere when the line was removed that it was enough to run the truck. new fuel pump and the truck ran fine......till I blew that motor up.............
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
