Clunk noise when loading drive train
Old May 17, 2011 | 12:31 PM
Outsane's Avatar
Question Clunk noise when loading drive train
I can hear and feel a clunk noise when I load the rear drive train.
I an usually feel it when I shift, if I feather the clutch I don't feel it as much.
Any one have any experience with this?
thanks
Old May 17, 2011 | 01:32 PM
Sensei's Avatar
Have you checked your u-joints for play ? That's the easiest component to check first. Could be other driveline components such as excessive gear backlash etc.
Old May 17, 2011 | 02:48 PM
SCToy's Avatar
my 81 does that exact same thing too, I greased my U-Joints and no difference, I can't feel any play in them when I mess with em. I guess I need someone to spin a wheel while its in gear so I can see what's going on while I'm under it.
I've looked around a good bit under the truck and the only thing i can figure is that the bushings on the transmission mount look really aged and worn out. I am planning on replacing my cross member sooner than later and hoping that fixes the problem. If not, I guess I'll be altering driveshafts when I swap my W56 in anyways
It did it before and after I replaced the gears in my truck. Not ruling that out, but that definitely isn't the problem in my case.
Old May 17, 2011 | 03:05 PM
Outsane's Avatar
I'll try yanking on the U-joints... new mounts sound like a good idea anyhow
Old May 17, 2011 | 03:46 PM
SCToy's Avatar
I found em pretty cheap online like 60 bucks I think. I was planning on just replacing the whole cross member with this
Much better clearance too
Old May 19, 2011 | 11:20 AM
Outsane's Avatar
well I checked the bolts, and they look to be tight..
I haven't gotten a chance to get under there and yank on the U-joints.. its been raining and the ground is wet..
but I did put in some new NGK spark plug wires and the clunk was gone on the drive to work..
on of the plug wire was loose on the distributor side.
I still want to find some transmission mounts...the Front Range set up looks nice.. but I want gears and lockers first...
Old May 21, 2011 | 05:00 PM
Outsane's Avatar
finally checked the drive shaft..
u-joint has a lot of play... I'll see what napa has to offer in the morning, not sure who else to trust with this part other then OEM
Old May 21, 2011 | 09:24 PM
sebastianholmes's Avatar
trail gear. they have OEM for ;ike 20 bucks and their creeper joints for like 40, if you dont mind waiting for shipping
Old May 22, 2011 | 06:11 AM
E-ROC's Avatar
ive got the clunk too on my 88 22re 5spd. u-joints are good. im starting to think it may be my clutch or t-case guts, i dont know. i also have tg bomb proof motor/t-case mounts. sure is annoying.
Old May 22, 2011 | 09:40 AM
SCToy's Avatar
How did you check the play in u-joints?
Old May 22, 2011 | 01:40 PM
E-ROC's Avatar
jacked up the axle. put it in first gear and released the e-brake to check the front joint(with front tires chocked of course). applied e-brake and put tranny in neutral to check rear joint.
Old May 22, 2011 | 03:06 PM
SCToy's Avatar
Thanks
Old May 22, 2011 | 04:01 PM
Mr.Utah's Avatar
I just fixed the same problem after much headache in troubleshooting. Lube and grease your SLIP YOKES on both driveshafts, it fixed my problem
Old May 23, 2011 | 10:12 AM
Outsane's Avatar
Ended up being my U-joints just as Sensei first suggested..
thanks for the help!
I did a little write up, its much nicer now.. on to the next issue
https://www.yotatech.com/forums/f115.../#post51726584
Old May 23, 2011 | 05:25 PM
E-ROC's Avatar
on it!
Old May 25, 2011 | 12:16 PM
SCToy's Avatar
Well, I have recently lubed all the zerks in my drive shaft, I just did the test and U-joints are fine. I did notice however, that when the rear wheels are off the ground I can feel that the ring and pinion gear have very little backlash play, but the locker allows for about 60-90 degrees of rotation of the driveshaft while the wheels are on the ground and not moving, but if I have the rear end jacked up the wheels will rotate with no play in the driveshaft. I think that my Aussie locker may be the culprit for my bang, as it is very similar to a worn u-joint in how it works.
Has anyone else had this problem? Both my front and rear Aussies do this. Both front and rear were installed professionally by a toyota offroad shop at the same time as the regear.
Old Jun 1, 2011 | 07:42 AM
E-ROC's Avatar
windedwalrus found a bad u-joint at my rear diff. changed that and lubed the slip yoke and no more clunk. as far as your lockers go that is of the norm. my 4runner had the same issue with a powertrax locker in it and i believe they are built the same. that thing would unload like a bomb! scared the poop out of people in parking lots all the time. kept me laughing instead of getting aggrivated.
Old Jun 1, 2011 | 07:49 AM
SCToy's Avatar
I can adjust my driving style to keep it from happening, which is probably a good thing anyways since it's a 30 year old truck. Think it's just a combo of the locker and my clutch bites pretty suddenly. U-joints are definitely fine, and I lubed the whole assembly about 3k miles ago. Maybe I'll hit the slip yoke again, I read somewhere not to over grease it incase you bottom it out suddenly.
smthwsn357
May 1, 2024 07:28 AM
mengquis
Jul 13, 2015 10:39 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
Poncho0206
Jul 10, 2015 06:21 PM
