84 4runner not starting
Old May 19, 2013 | 06:18 PM
84runnerWa's Avatar
I have a 84 4 runner with a 22r and its not starting turns over but won't fire getting spark and fuel to the Carb and help would be great thanks
Old May 28, 2013 | 06:13 PM
crashnburn80's Avatar
Did it run while you owned it and then one day didn't start? Or has it never run while in your possession? Have you tried spraying carb cleaner down the air intake and then try starting it? If it does not try to start, you can likely eliminate fuel issues as the culprit.
Old May 29, 2013 | 08:06 AM
84runnerWa's Avatar
Yea it ran when I got it running one day then went to go out wheeling with a buddy and all it would do is turn over I have gas in my Carb and the spark plugs are wet I think I've got it narrowed down to electrical issues
Old May 29, 2013 | 09:23 AM
Stetson_md's Avatar
Is it getting air?
Old May 29, 2013 | 06:44 PM
84runnerWa's Avatar
Yea its getting air I had a buddy look at it and he was saying it sounded like the coil or the igniter
Old Jun 7, 2013 | 01:06 PM
84runnerWa's Avatar
Had my igniter tested and coil are good getting spark fuel and air back to a dead end
Old Jun 7, 2013 | 01:31 PM
solid4runner's Avatar
I think they just went through this a few weeks ago. Dizzy cap and rotor have to be new to work. Water vapor gets in there and inhibits spark. Spray some silicone spray on wires as well.
Old Jun 14, 2013 | 08:10 PM
84runnerWa's Avatar
New cap rotor wired plugs coil still not firing inconsistent spark gas is going through the Carb but not making plugs wet
Old Jun 15, 2013 | 07:04 AM
ojm3's Avatar
Timing
Old Jun 15, 2013 | 07:07 AM
Team420's Avatar
Have you done a compression test? If not...I would start there. If you have low/uneven compression... thats your problem. If compression turns out fine, at least you know you have a healthy motor....
Old Jun 15, 2013 | 08:28 AM
84runnerWa's Avatar
Compression is good around 165 across and the timing lines up with tdc and marks this one is even stumping the mechanics at the shop I work at
Old Jun 15, 2013 | 03:48 PM
ojm3's Avatar
Is the cam in time?
Old Jun 15, 2013 | 04:10 PM
84runnerWa's Avatar
From what the cam gear says unless someone else did it wrong the thing is it ran one day and the very next day went to go out and all it did was turn over
Old Jun 16, 2013 | 07:53 AM
ojm3's Avatar
I bet your camtiming has jumped
Old Jul 8, 2013 | 09:28 PM
84runnerWa's Avatar
Checked it out its timed right cause I retimed it and I still am only getting spark to the number one cylinder I have new plugs wires pick up coil new coil and igniter rotor cap still no start this is bad
Old Jul 9, 2013 | 05:41 AM
ojm3's Avatar
Distributor?
Old Jul 10, 2013 | 07:21 PM
84runnerWa's Avatar
Yep finally got the money for a new one started right up its crazy that it was throwing all the right numbers but no spark haha
Old Jul 10, 2013 | 07:22 PM
84runnerWa's Avatar
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
torgeir
Jun 25, 2015 05:26 AM
JF9243176
Jun 24, 2015 04:53 AM
JaredL
Jun 16, 2015 04:47 PM
