30 spline Longfield install with pics.
Old 09-26-2006, 11:34 AM
  #61
waskillywabbit's Avatar
Originally Posted by Pa bowhunter
Thanks the side that was leaking the worst is done. I'll do the other side this weekend. I have the Warn locking hubs and the don't use the cone washers. I have a spare front diff from a parts truck that has the stock hubs which is better should I swap them?
Use the Aisins (OEM) and not the Warns IMO as the Warns are notorious for coming loose and busting.
Old 09-29-2006, 01:49 PM
  #62
Pa bowhunter's Avatar
Thanks again that link is great robenhood. It explained the martack so even I could understand it. I'm starting the otherside now and I'll swap the hubs on both to the Aisins hubs. Hopefully they come off the bone yard diff without too much hassel. I'll let you know how I make out.
Old 05-19-2009, 10:56 AM
  #63
87chevyota's Avatar
alittle help?
Hey the pics you have posted are great, i am planning on the same project except with mine is a different case. i was out wheeling and my tires are way too big, so when it flexed it stuffed the front tire into the wheel well. causing something to break in the front end. I took it out with zero miles on the new detroits and longfields. do you think it is something else then the longfields? or maybe hubs? im new at this. i called longfield and they said i can send them in and get a new set. i have switched to 36 iroks in place of my 39.5s i had on it. any advice?
Old 05-19-2009, 01:39 PM
  #64
1985 4Runner's Avatar
Could you be more specific on what broke in the front end?
Longfields have a lifetime guarantee last I heard, but I doubt you broke the longs.
I am glad this old thread helped though.
Old 05-19-2009, 01:50 PM
  #65
toyospearo's Avatar
HOLY CRAP DUDE, nice write up and great pictures!
Great looking truck!
Old 05-20-2009, 06:05 PM
  #66
87chevyota's Avatar
now to reassemble
yea i got it figured out, the pics were the best help ive had. it was some jap brand berfields that were junk and broke the bells in half. i got a used set of longfields from a buddy for half price. thanks for the info!
Old 10-13-2012, 07:09 PM
  #67
INKUBUS's Avatar
Inner axle seal
Originally Posted by 1985 4Runner
Once the dust cover is off, the knuckle spindle can be removed:
Which exposes the objective, the axle shaft...
I felt like I was delivering a baby....
Here she is:
After delivery...
Inner axle seal: (this little thing gave me quite a headache, I didn't have a seal puller)
what is the cause of this grease combination and oil???
its a bad Inner axle seal???
i have the same problem
regards
Old 10-13-2012, 07:27 PM
  #68
rokblok's Avatar
Bad axle seal causing gear oil to leak into the knuckle and mix with the grease.
Old 09-25-2013, 02:52 PM
  #69
Quagland's Avatar
Did you not have to grind anything to get the longfields to fit?
Old 09-26-2013, 01:17 PM
  #70
osv
osv's Avatar
in theory, no... however, some people have to, some do not... i did not have to grind.
when you put the longfield birf into the housing, you must make sure to use the c-clip listed in the picture below... that clip holds the birf into the brass bushing, without it the birf will back out a bit and flop around inside the knuckle ball.
you'll see many people stupidly leave that clip out... bobby specifically said that it must be there... my axle did not have that clip, and the longfield birf was grinding around inside the knuckle ball.
when you take the axle apart, make absolutely sure to keep track of where the upper and lower factory shims are located... those shims perform two functions: 1)they center the birf to some extent, 2)they apply drag to the trunnion bearings.
there is a factory service tool that measures both of those clearances, in case someone has messed with the shim settings.
A2theK
01-10-2016 10:18 AM
mavenator
08-13-2015 01:12 AM
falcon4runner
3.4 Swaps
08-06-2015 02:36 PM
SMOD
07-23-2015 10:29 PM
Quick Reply: 30 spline Longfield install with pics.
