22re cam
Old Aug 25, 2018 | 08:18 PM
85basemodel's Avatar
22re cam
hello guys i bought a 22re with a lc stage 3 cam and im having the problem of when i put it in gear it dies i have a auto trans and its in a 1985 toyota pickup i have talked to several people and they said its the cam its too large Any ideas of what i can do im thinking about putting a smaller cam but id like to see what you guys have to say about it
Old Aug 25, 2018 | 09:23 PM
gsp4life's Avatar
On their website LCE notes that a stage 3 cam "will not work with the stock 22re computer. Requires stand alone engine management for fuel injected applications".
So, how stock is the rest of the engine and it's electronics?
Old Aug 25, 2018 | 09:25 PM
stock
Old Aug 25, 2018 | 09:27 PM
its all stock electronics i got a good deal for the engine and i jumped on it and made the mistake of not doing my research
Old Aug 25, 2018 | 09:31 PM
gsp4life's Avatar
Well congrats on the good deal. Sounds like someone may have thrown some fancy racing parts at a stock setup and sold it when it didn't work. That's ok, now you get to make it right. Buy a stage 1 or just stock cam (nothing wrong with stock parts believe it or not, Toyota knew what it was doing!) and get that engine back to running condition.
Old Aug 25, 2018 | 09:39 PM
yeah that is my option is it simple to replace a cam from what you know? i will also do my research
Old Aug 25, 2018 | 09:54 PM
gsp4life's Avatar
Normally you'd want to replace the headgasket if you're pulling the valve train (held down by head bolts) to access the cam underneath. But, if you run a few ratchet straps under the rocker towers and camshaft down around the entire engine, you have a workable shortcut. Use the manual to loosen and pull the head bolts in the correct order, yes it does matter or you can warp the head.
​​​​​​If you were to release all the pressure between the head and block, then the head gasket will shift slightly and never seal right again. Strap it down and you will be able to loosen the 3 cam caps and install the right part. 14 ft/lbs, iirc and use a good torque wrench, it's well worth it to get those values right.
Old Aug 25, 2018 | 09:57 PM
thanks for the info ill see what i can do
Old Aug 25, 2018 | 10:07 PM
gsp4life's Avatar
Ask more questions if there's anything you're not sure of. I read a thread on yotatech some years back about strapping the head down to replace a cam. I did it and so far so good thousands of miles later.
Old Aug 26, 2018 | 02:48 PM
what would be the best cam for the 22re i was thinking about a stage 2 or the efi pro from lc its an auto trans and id like i bit more power than stock since im running 35s with stock gearing
Old Aug 26, 2018 | 03:01 PM
gsp4life's Avatar
A cam won't give you any more power, what it's actually doing is just moving the power band.
A cam made for low-end torque should help a little bit from a dead stop, but with 35's you really would do best to regear.
Old Aug 27, 2018 | 09:41 AM
Alright thanks
Old Aug 27, 2018 | 09:53 AM
i have a compession ratio of 9:8:1 and what do you think would be the best cam without having the same problem of it dying when i put it in gear?
Old Aug 27, 2018 | 10:27 AM
gsp4life's Avatar
Engnbldr has the 261c crawler cam, which is made to prioritize low-rpm torque. I don't know if they have those in stock right now, but any mild cam meant for a rock crawler will be your best bet.
Old Aug 28, 2018 | 03:53 PM
and do you know if thats going to get rid of that idling issue?
Old Aug 28, 2018 | 04:52 PM
gsp4life's Avatar
I have no idea how many contributing factors there are going on with your truck, but I know that your cam isn't meant to work with the stock ecm. That alone would have me wanting to change it out for something closer to stock, but it doesn't guarantee that things will all work great after it's in.
Old Aug 28, 2018 | 04:54 PM
alright thanks ill see what i can do and wht i can find out I understand were you coming from
Old Aug 29, 2018 | 06:09 PM
L5wolvesf's Avatar
Along a similar line to what gps said. Some cams require other parts that work best with the cam for instance - bigger valves or rocker arms (and perhaps with a different ratio). And, that, or those, different part(s) may not be compatible with a stock cam/motor. Also, has any porting or other machine work been done on the head? .
Old Aug 29, 2018 | 06:12 PM
Thanks yeah i found out stage 3 head wont work with a 22re ecu so im just gling to rebuild my old motor
AH64ID
9
Aug 16, 2005 09:19 AM
guitarsncars
Aug 2, 2003 12:11 AM
