22r running too rich help please!
Old Jul 18, 2009 | 07:58 AM
85beatertruck's Avatar
well i just got done swapping an 89 22r into my 1985 toyota 4x4. i used the 89 carb but swapped everything from the 85 carb onto it but clearly i must of done somthing wrong. when i start the truck it runs fine for a little bit without any smoke but after a couple of minutes of running the it starts to blow out black smoke and then it would just die if i give dont give it gas. when its running i check the fuel mixture level on the carb and its completely full of gass. i dont really know where to even adjust the fuel mixture so if you have any suggestion that would be great thanks.
Old Jul 19, 2009 | 11:49 AM
myyota's Avatar
Try putting the stock carb back on and see if that fixes the problem. The carbs may look the same on the outside but sometimes they make internal changes, like diferent jet sizes and other minor things, and something like that could be causing your problems.
Old Jul 20, 2009 | 07:32 PM
i think i would of already done that if i had the 85 carb. anyone else?
Old Jul 20, 2009 | 08:19 PM
oldgold3vze's Avatar
Man, I know this doesn't help too much, but I dorked around with my stock, and other stock carbs for way too long until I finally just went for the Weber. Now that I have it, I'll never look back. So easy to tune, runs so nice, better mileage. I wish I had more help for you, sorry.
Old Jul 20, 2009 | 09:22 PM
myyota's Avatar
You don`t need to come off like a jerk, the whole idea of a forum is for people to throw out ideas to help each other, so how was i supposed to know you didn`t have the carb for the 85 ???.
Old Jul 21, 2009 | 05:33 AM
83's Avatar
83
Totally. If you don't mention it in your original post, how would anyone know?
Old Jul 21, 2009 | 12:31 PM
84yotaman's Avatar
jerkoff!!!
Old Jul 22, 2009 | 08:07 PM
ok i guess i did come off as a jerk and i apologize cause i really didnt specify that my 85 carb needs a rebuild. unfortunately i didnt have money for a rebuild and i had a friend that wasnt using his 89 carb with low miles so i decided to use that one.
sandyota
Feb 4, 2021 11:16 AM
young buck
18
Aug 27, 2018 02:40 PM
cars-guy
Jul 11, 2015 07:51 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
87blyota
Jul 10, 2015 04:31 AM
