Pre 84 Trucks 1st gen pickups
What transmission is this?
Old Mar 18, 2008 | 06:43 PM
87toy.'s Avatar
Not sure what this is, i cant find a picture of a l45.
anyhelp is appreciated, The motor and tranny are for sale if you want them.
Old Mar 18, 2008 | 06:51 PM
rowdy235's Avatar
the 200090 on the side is also on the side of my w50
Old Mar 18, 2008 | 06:53 PM
DeathCougar's Avatar
If its really from a 79 truck as you stated, it will be a W42.
Old Mar 20, 2008 | 03:19 PM
87toy.'s Avatar
is it worth anything?
Old Mar 20, 2008 | 07:42 PM
87toy.'s Avatar
the number on the side of the trans is 33111-20090.
Old Mar 20, 2008 | 08:09 PM
rowdy235's Avatar
Though yours looks a little different,
the numbers are the same as on the side of mine- w50 (5-speed)
a somewhat better way of telling, does yours have 33141-20090 stamped towards the rear? if so, i'm 999.9% its a w50
Old Mar 21, 2008 | 07:23 AM
87toy.'s Avatar
Ill check tonight. Would you happen to have a extra shifter?
Old Mar 21, 2008 | 02:22 PM
rowdy235's Avatar
sorry no luck, mine is in need of rebuild anyway.
But I think the w50's were more common in celicas, you might check there too.
Old Mar 21, 2008 | 05:06 PM
87toy.'s Avatar
well i have a good one for you. i drained the tranny fluid the other day and stuck a magnet in it and there is no metal shaving in it. all the gears spin smooth.
Old Mar 21, 2008 | 05:40 PM
Phssthpok's Avatar
Aluminum bell housing/cast iron midsection/aluminum tail shaft housing = W50 5 speed 2WD....just like the one in my '79 longbed.
Old Mar 24, 2008 | 09:10 AM
87toy.'s Avatar
will a transfer case bolt up to this?
Old Mar 28, 2008 | 04:10 PM
4banginRunner's Avatar
probably not
the 1st 4x4 trans was the L43 4spd, which was a 2wd trans with an alum adapted between the trans and t-case
Old Mar 28, 2008 | 05:17 PM
rowdy235's Avatar
hey I may be interested in that, but not right away. Does 5th make a whirring noise? Can you even tell spinning it by hand?
Actually come to think of it i'll take the enigne too (if its a 22r not 20r)
Old Apr 4, 2008 | 09:05 AM
87toy.'s Avatar
i cant tell if it does by hand, but its really smooth through all the gears. and its a 20r
Old Jun 5, 2009 | 11:33 AM
Airborne1337's Avatar
I have a similar transmission to this however, instead of SK-31 below the rear case I have SK15A. Does this change anything? Also how much are one of these puppies worth?
Thanks,
John
TheBFA
Feb 15, 2020 06:55 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
briholt
Sep 20, 2015 10:26 PM
