Pre 84 Trucks 1st gen pickups
Removing Steering Box
Old Apr 30, 2018 | 07:03 PM
GodwinAustin's Avatar
Originally Posted by akwheeler
remove the bolt, not just loosen, remove. then work the collar off of the splined shaft, it may help to lightly tap a chisel into the slot to spread it slightly. don't get all King Kong with it or you will break it. It may also help to unbolt the steering box from the frame to get the last little bit.
sprayed it with pb blaster tonight, and yeah was gonna unbolt the steering box FIRST, then try and pull the spline off - figured that would be easier. Thanks for all the help AK
Old May 1, 2018 | 11:51 AM
Alright so was able to rubber mallet a wedge into the collar and popped it off. Everything is back together!
Is there a way to tell if the drag link ball is seated correctly in metal sleeves inside the link?...After turning the set screw in as far is it would go, there is one thread showing on the end of the drag link.
CobraRed
Jun 30, 2014 01:36 PM
2shots1beer
Dec 31, 2012 06:50 AM
stanz
Dec 12, 2011 03:06 PM
cr@ves4wheelin
Jun 25, 2011 12:41 AM
Bugzman
Mar 25, 2011 07:52 AM
