Pre 84 Trucks 1st gen pickups
How to tell what Tranny you have?
Old Dec 18, 2011 | 06:25 PM
funcrazy1's Avatar
I would like to know what tranny I have in my 22r 2wd 83 p/u It is a 4speed I would like to drop it out and put a 5 speed tranny since I drive around 55-65 alot would love to have a 5 speed. If someone could tell me how to find out what tranny I have and what would be the easiest tranny to put in.
Old Dec 18, 2011 | 06:37 PM
aadown1214's Avatar
If you have an 83, and it's a 4spd, you probably have an L50. DO you know if the shifter goes in the top of the trans or is there an external linkage on the passenger side? The linkage will be on the outside of course. That should get you started.
Old Dec 18, 2011 | 06:46 PM
funcrazy1's Avatar
Okay thanks AA I will look tomorrow morning and post pics I would like to know what tranny I have and what other 5 speed tranny is the easiest to swap in .
Old Dec 19, 2011 | 10:16 PM
funcrazy1's Avatar
Also I think you mean L40? cause a L50 is a 5spd not a 4spd. Looking tomorrow had some stuff to do
Old Dec 22, 2011 | 06:50 PM
aadown1214's Avatar
That's my bad, found this for you:
Type, Year, Behind, # of Gears, Low Gear
L43 1979-1980 20R 4 3.67
L45 1981-1982 22R 4 3.93
L50 1981-1982 22R 5 3.93
L52 1983 22R 5 3.93
http://www.4x4wire.com/toyota/faq/parts/
Old Jan 9, 2012 | 05:22 PM
Born2buggy's Avatar
I am building a 1980 4x4 for a friend. It came with a 20r and a 4 spd. We will be swapping out the locked up 20r for a 22r. I have a 5 spd and transfer case out of a 1985 that we would like to put in it. I think it would be easier to put in both tranny and case but thought I would get some expert opinions. The 4 spd has the linkage on the side of the tranny if it matters.
Old Jan 9, 2012 | 07:23 PM
dropzone's Avatar
Fossilized
85 transmission is gonna be 4" longer. Need to move the crossmember back. Lengthen front driveshaft and shorten rear..
Old Jan 10, 2012 | 03:56 AM
Born2buggy's Avatar
He is going to drive this alot of miles as a dd and is looking to help fuel economy. Will the 5 spd be worth the trouble? The body is off to restore the frame so now is the time to do it if.
Old Jan 10, 2012 | 06:19 AM
83's Avatar
83
If he's going for daily driver, lots of miles and fuel economy, absolutely the 5 speed is worth the trouble. I don't know anything about the 2wds, but 4wd wouldn't come with a 4 speed stock. Not in a manual, anyways. Somebody swapped one in when the 5 speed went out if it has one. Like the post above shows, 83's didn't come with 4 speeds.
But like I said, I don't really know about 2wds.
Old Jan 10, 2012 | 05:46 PM
Born2buggy's Avatar
Thanks for the help. The owner wants to go with the 5 spd so thats the direction were heading. I may have the driveshafts out of the 85 if they will work but either way here we go. Thanks again.
Old Feb 13, 2012 | 05:35 PM
82shorty's Avatar
updates??
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
