Pre 84 Trucks 1st gen pickups
Fuel Idle Cut Solenoid
Old Jan 14, 2011 | 07:41 AM
C17loadclear's Avatar
Can someone please post a pic of the fuel idle cut solenoid. My book says Cali trucks didnt come with one and I want to see what it actually looks like.
Thanks
Old Jan 14, 2011 | 08:03 AM
xxxtreme22r's Avatar
what book is that? My "book" says this:
VALVE, SOLENOID
21347-35420 Replaced by: 21347-35510 1986.08-1987.08 22R.. RN5#.. USA
Manufacture notes: CALIFORNIA SPEC
Old Jan 14, 2011 | 08:08 AM
coryc85's Avatar
Here is one I removed from my '83 pickup, which BTW, I bought in California. Not sure if it was originally a Cali truck or not:
Old Jan 14, 2011 | 08:14 AM
hey coryc85, I don't have mine any longer, but do you remember at the end of that having a removable jet like the weber idle solenoids?
Old Jan 14, 2011 | 08:31 AM
coryc85's Avatar
xtreme - I don't think anything is removeable on this thing except for that little o-ring on the tip. Of course, I could be wrong.
Old Jan 14, 2011 | 11:42 AM
My Hanyes manual says Cali exempt in the wiring diagram. Thanks for posting a pic. I dont have anything like that on my carb. I do have a solenoid on the passenger front side but it does not look like that. It has a spring with a rubber washer on it.
This is a factory truck with no mods as it was my dads (I learned to drive with this truck)
It is a 1981 SR5.This thing is driving me crazy trying to figure out the idle problem.
Old Jan 14, 2011 | 11:47 AM
I will check what toyotapartszone says on the 81 the one I checked you can see the years the cali spec included.
The solenoid you describe sounds like the outer vent solenoid. As I don't believe there is any other sol. on the carb.
Old Jan 14, 2011 | 01:34 PM
83's Avatar
83
If I remember correctly, the idle fuel cut solenoid is on the passenger side rear of the carb. So if you've got nothing there, then yeah, you must not have one. It is a "common" cause of stalling on these trucks though, even with rebuilt carbs.
Old Jan 15, 2011 | 04:23 AM
I have read the trouble with rebuilding and was wondering if anyone has bought a reman carb from someplace and had good luck with it...If not, I guess I will go the way of the weber.
Of course, then I have to deal with all the emissions stuff.
Old Jan 18, 2011 | 11:08 AM
83's Avatar
83
I bought a rebuilt carb. It's works great...except for the idle cut solenoid going bad
They don't replace that part in the rebuild.
Old Jan 26, 2011 | 08:03 AM
Soon's Avatar
Did you ever solve the problem? I had an idle problem and thought it was the fuel cut solenoid and it turned out to be the EGR valve.
Old Jan 26, 2011 | 02:18 PM
Smile
Hey Guys,
Sorry to have not posted sooner...The problem was the solenoid but I think the EGR is bad also as it doesnt pass the vaccum test. The truck is idling a little rough but at least it is running all the time now. I am thinking about blocking it off rather than fork out 200 bucks. Whatcha think?
Thanks for all the help.
Todd
Old Jan 27, 2011 | 04:59 AM
Soon's Avatar
I put a little bolt into the vacuum line to the EGR valve which effectively blocked it off and its been running perfectly ever since.
Old Jan 27, 2011 | 11:37 AM
83's Avatar
83
I just plugged all the egr lines with golf tees. Someday I'll make a blockoff plate. The EGR is probabaly a good thing when functioning properly. But in trucks this old, they're pretty much never functioning properly, and the easiest most cost effective fix is just blocking them off.
Old Apr 11, 2014 | 08:25 AM
esievel's Avatar
fuel cutoff solenoid
I just had my first experience with this solenoid. Didn't realize this would be on a non fuel injected vehicle. I was given a jump by someone who accidentally crossed the connection. It blew the fuses of everything that comes on with the ignition. I couldn't keep an idle. Fortunately I found a thread on this forum that lead me to the issue. Nice simple fix.
Old Sep 30, 2014 | 01:11 PM
Ange5583's Avatar
Hi
Last weekend my son jumped incorrectly and damaged the Alternator, replaced it but now engine wont idle. How did you repair your solenoid not working?
Old Sep 30, 2014 | 03:31 PM
esievel's Avatar
fix for fuel solenoid
A fuse. I don't recall what it was listed as but it was a fuse.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
v_man
Jul 23, 2015 04:01 PM
Fundy Rider
Jul 16, 2015 01:35 AM
Jnkml
Jul 6, 2015 01:20 PM
