Pre 84 Trucks 1st gen pickups
81 pickup multiple questions
Old Mar 14, 2013 | 08:31 AM
  #141
parkerst02's Avatar
Yeah probably be able to make them but no one around here can for some reason
Old Mar 20, 2013 | 09:30 AM
  #142
parkerst02's Avatar
Ok i got lift blocks on my truck to clear the oil pan better i didn't like how close it was to the front diff. Now the steerin is stuck on leaf springs do i need high steer
Old Mar 20, 2013 | 11:17 AM
  #143
SCToy's Avatar
Should use shackles instead, cost you less than hi steer and a lot less work too.
Old Mar 20, 2013 | 11:47 AM
  #144
parkerst02's Avatar
How would shackles work?
Old Mar 20, 2013 | 01:10 PM
  #145
SCToy's Avatar
Remove lift blocks, add longer shackles. Will keep the extra lift you wanted without dropping the axle relative to the leaf springs which is causing your current steering issue.
  #146
SCToy's Avatar
Of course the amount of lift you can get that way is limited, but its cheap and easy.
Old Mar 20, 2013 | 01:21 PM
  #147
parkerst02's Avatar
True but do they make around 3" shackles
Old Mar 20, 2013 | 01:36 PM
  #148
parkerst02's Avatar
And is high steer the only way to fix it and is there a high steer for sas
Old Mar 20, 2013 | 01:39 PM
  #149
parkerst02's Avatar
This is what I'm facing
Old Mar 20, 2013 | 01:52 PM
  #150
SCToy's Avatar
Check online vendors, pretty sure you can get shackles in just about every length.
Old Mar 20, 2013 | 03:18 PM
  #151
parkerst02's Avatar
Will this not fix it
Its skyjacker tdl5 on ebay
Old Mar 24, 2013 | 07:00 AM
  #152
parkerst02's Avatar
will 84-89 rear leaf springs work on a 81?
Old Mar 24, 2013 | 07:42 AM
  #153
4Crawler's Avatar
I've found the dimensions to be similar:
This page shows they are a little different:
- http://4x4spot.com/misc__spring_information.htm
I prefer the '83 and older rear springs as they have more leaves and free arch. Only other minor difference is the ID of the front spring eye and hanger bolt. The '83- use 30mm/18mm and the '84+ use 40mm/14mm (with a sleeve). So you would need to deal with that issue or make a hybrid pack with the '83- rear main leaf and the rest of the '84+ leaves.
Old Mar 24, 2013 | 07:44 AM
  #154
4Crawler's Avatar
Attachment 91548
Precisely what I Was describing with too thick a front leaf and stock steering, BTDT. Crossover steering is the fix if you need that thick a leaf pack. ANopther option if it is u-bolt clearance issue is to get the OME front u-bolts. They make a set with the side of the u-bolts flattened for a bit more clearance and maybe get their heavy duty front springs:
http://www.arbusa.com/
Old Mar 24, 2013 | 07:57 AM
  #155
parkerst02's Avatar
I got shackles coming in for the front and i was wondering about the rear springs bc i found some 6" lift springs for 84+ for 100 thought that was a good deal
Old Aug 11, 2013 | 12:33 PM
  #156
parkerst02's Avatar
Well have had it going for awhile now and started having transmission problems it keeps on coming out of reverse and grinding I can't even hold it in gear does anyone know what causes this
Old Aug 11, 2013 | 12:37 PM
  #157
parkerst02's Avatar
Old Aug 11, 2013 | 12:38 PM
  #158
parkerst02's Avatar
What it looks like right now but not done yet just tight on money right now
Old Aug 23, 2013 | 08:33 PM
  #159
parkerst02's Avatar
Well have had it going for awhile now and started having transmission problems it keeps on coming out of reverse and grinding I can't even hold it in gear does anyone know what causes this it does it every time put into reverse
Old Feb 22, 2015 | 02:30 PM
  #160
parkerst02's Avatar
How can you tell what transmission you have I don't see any numbers on it
