Pre 84 Trucks 1st gen pickups
22r question
Old Mar 21, 2009 | 08:28 AM
yotaboy82's Avatar
22r question
ok so i put new oil in my 22r, and after a few runs the oil looks thinner and is runny, there is no antifreeze in it and the oil smells like gas....is there somthing wrong with it or is this normal...
Old Mar 21, 2009 | 08:51 AM
Dieselfuel12v's Avatar
Hows your compression? Might have gas washing past the rings.
Old Mar 21, 2009 | 09:23 AM
TOYOTA 1's Avatar
bad fuel pump diaphram!
sometimes when a manual fuel pump goes bad, it will spew gas into the timing cover/block!
i would check that first...
Old Mar 23, 2009 | 05:41 AM
83's Avatar
83
What he said
I had my fuel pump do that. Leaking some oil out, and putting gas in. But I'm guessing there are other things that could do it.
Old Mar 24, 2009 | 06:14 AM
slisdexia's Avatar
I'd say the fuel pump is the easiest to check, just unbolt it. otherwise, tear into your motor to check the rings and cylinders
Old Mar 24, 2009 | 01:13 PM
yotaboy82's Avatar
i would rather not tear into my motor....just for the fact i just drove it home dont have a shop now .....but i will check the fuel pump
Old Mar 24, 2009 | 01:32 PM
83's Avatar
83
Yeah I guess if the rings weren't sealing right you could get some gas by them, but wouldn't that also mean you're dumping gas into the cylinders? Otherwise it seems like if there was the correct amount of gas getting into the cylinders it would burn off before getting down into the oil.
I don't know enough about engines, though. Is it running fine otherwise?
Old Mar 24, 2009 | 02:00 PM
slisdexia's Avatar
the gas would be pushing past the rings before it gets to the spark, wherever that happens to be set, so it's probably pushing gas down into the crankcase from bottom dead center to approx. 7 degrees btdc. I wonder if it's running rich
Old Mar 24, 2009 | 06:11 PM
yotaboy82's Avatar
ya it runs a little rich...but only till the choke comes off.....but im thinking and HOPING its the fuel pump.......because i just want to drive the stupied thing
Old Mar 26, 2009 | 05:04 PM
yotaboy82's Avatar
ok another thing i forgot to add was....when i first hooked up all the fuel lines on my truck i had them all wrong and i was pouring some gas down the carb to try and make it run...it did for a few secs then stops, so i was maybe thinking there was fuel going places that it shouldent and somehow got into my oil?....im not sure thoe.....and is it bad to run it like that?
Old Mar 27, 2009 | 05:14 AM
83's Avatar
83
It's not good. But nothing an oil change won't fix. If you had run it a few thousand miles I'd worry more.
Old Mar 27, 2009 | 06:18 PM
yotaboy82's Avatar
ok so i found the problem....the fuel pump was shot....i pulled it off and it was like dripping fuel...so my intsinks told me that dripping fuel was getting in the oil....and that would also be the reason my truck wont stay running at higher rpm...it will go to 5k than die...anytthing below that is fine
Old Mar 30, 2009 | 05:34 AM
83's Avatar
83
Let us know if you're right! Luckily that's an easy thing to replace. Only trick is making sure the "lobe" or whatever it's called on the cam gear is on the low side when you put the new pump in, so you don't have to compress the pump lever to get your bolts to thread. Ask me how I figured that one out.
colasurdo
Jan 11, 2026 08:10 AM
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
cars-guy
Jul 11, 2015 07:51 PM
