Pre 84 Trucks 1st gen pickups
22r exhaust manifold gasket
Old May 20, 2009 | 11:07 PM
Csull's Avatar
in the process of putting my exhaust manifold back on and i have 2 manifold gaskets, i know one is for use from head to heat shroud, and one for heat shroud to manifold. the question is "what gasket goes where"
one is paper faced on both sides, and one has both metal and paper face.
Old May 21, 2009 | 05:40 AM
83's Avatar
83
I'm not aware of a gasket that goes from the head to heat shroud...have a photo of where it would go? I can't picture it. My exhaust manifold gasket had metal in it. My heat shroud (if I'm thinking of the same thing you're talking about) just bolts onto my exhaust manifold with maybe 3 bolts and there's nowhere for a gasket.
If you have a photo of the gaskets I think we'd be able to tell you were they go no problem.
Old May 21, 2009 | 11:02 AM
scottd's Avatar
I just put new gaskets on mine a few months ago. I'm pretty sure the directions that came with the gaskets said to put the paper/paper gasket between the head and the manifold and to put the metal/paper gasket between the manifold and the heat shroud with the metal face towards the heat shroud. I am sure about the placement of the paper/paper gasket. Not 100% sure about which way the (metal/paper gasket faces) - maybe 90% sure.
Old May 21, 2009 | 11:37 AM
Csull's Avatar
this sits one the head and has gasket in between
back of the metallic gasket is paper
Old May 21, 2009 | 07:38 PM
yotaboy82's Avatar
on the manitfold to the head is paper to the inside...metal on the out side
Old May 21, 2009 | 11:24 PM
Csull's Avatar
phew, that was my educated guess today and i went for it.
Thanks for setting me at ease about that. haha
Old May 22, 2009 | 05:20 AM
83's Avatar
83
Wow. That's absolutely nothing like my truck...Glad it worked out for you!
Old May 23, 2009 | 07:22 AM
crazykooter's Avatar
Thats an exaust manifold off a 84' or newer yota. The earlier models have the heat riser on the top. Those are much much better since the riser tube mounts with the exuast bolts. I am about to go get me one of those manifolds for mine since I cant get my tube to seal anymore. Early models ones just suck for that.
Old May 26, 2009 | 06:02 AM
83's Avatar
83
Interesting. There's always something to do with these trucks. Just when I think I've got it "done"...
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
87blyota
Jul 10, 2015 04:31 AM
