Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
welding gas quick disconnect
Old Mar 26, 2010 | 05:47 AM
dfoxengr's Avatar
I am getting ready to buy a millermatic 252 with spool gun. I currently have a 110 miller mig and a tig welder. I have 2 bottles, argon and 75/25 and dont want to buy 2 more bottles to put on the 252 cart so I am looking for a quick disconnect system that would attach on the back of the machine and allow me to quickly swap machines.
any ideas?
Old Mar 27, 2010 | 07:49 AM
4Crawler's Avatar
Might check at a local welding supply shop and see what they recommend. Or I would think a regular compressed air disconnect would work there, low pressure after the regulator. Type I or Type T chucks would probably be easy to find:
Old Mar 28, 2010 | 07:01 PM
TC4RNR's Avatar
I've been using push-in fittings for years, never had a problem. 1/4" OD clear beverage hose is only 20 cents per foot.
the fitting itself is about $3-5 depends where you buy them. this one in the picture is brass, but, I've used white plastic ones, they are just as good.
Old Mar 29, 2010 | 02:19 AM
wyoming9's Avatar
Red face
This is what I do because I have several welding machines set up at different parts of my lawn shed it works for me.
I have a normal every day cylinder cart most often seen in use with a oxy- fuel set up one cylinder 75/25 one pure Argon. 2 flow meters 2 hoses easy to move quick to change cylinders
All I need is a 11/16 wrench which stays in the tray on the cart
This was just one of those pure chance things that worked well because I had the cart and it was just sitting there .
Old Mar 29, 2010 | 06:12 AM
dfoxengr's Avatar
so can someone link me to the quick change fittings on a site?
thanks for the help
Old Mar 29, 2010 | 06:18 AM
Tofer's Avatar
Sponsor
Old Mar 29, 2010 | 06:36 AM
dfoxengr's Avatar
i have been but cant really find argon specific ones.
Old Sep 9, 2010 | 06:21 AM
dfoxengr's Avatar
any other ideas?
Old Sep 12, 2010 | 02:42 PM
wyoming9's Avatar
Red face
I did see a manifold set up a while back that used quick disconnect fittings if I recall the fittings were very expensive$$$
I looked into doing it . they might have come down in price but till i priced out the fittings I needed it would have paid for a few cylinder fills so I gave up on the idea.
Like said check with your local supplier
** I just looked Air Gas has them in the Catalog to fit B style Flowmeters they are color coded Blue for inert gas
Old Sep 12, 2010 | 07:31 PM
dfoxengr's Avatar
yeah i looked at the oxy/acet setups and they are like 30$ per pair. wondering if air hose disconnects would work like roger mentioned...
Old Sep 13, 2010 | 12:13 AM
wyoming9's Avatar
Red face
They should work for you but I would get the twist lock kind so you don`t uncouple them by mistake.
Air is cheap compared to inert gas so you want to keep your hose as short as possible .That you are plugging into the female connector to keep your inert gas loss as little as possible
I would for sure break out the soap bubbles to be checking for leaks.
Old Sep 13, 2010 | 04:30 AM
dfoxengr's Avatar
yeah, I was going to look up molecule size of air vs argon to see what kind of differences the seals might make also...
smthwsn357
May 1, 2024 07:28 AM
jasonty
41
Dec 23, 2018 01:00 PM
young buck
18
Aug 27, 2018 02:40 PM
ryerye13
Jul 14, 2015 08:27 AM
Jnkml
Jul 6, 2015 01:20 PM
