What would you rather have? (33s + lockers vs 35s + no lockers)
Old 03-18-2005, 11:24 AM
Tacoma750's Avatar
So would you rather have a 1st GEN 4RUNNER on 35s with only a lift and regear, or a 1st gen 4runner with 33s,lift,regear and locker?
Im leaning toward the 33 package, but the extra tire size might be nice to have. ADVICE?
Old 03-18-2005, 11:26 AM
X-AWDriver's Avatar
How big is each lift? Lower miles? Are they in the same condition? If they are I think the locker would tip the scales a bit since a retrofit on the other would just add to the cost.
rimpainter.com's Avatar
33 package, given the rigs were in the same or similar condition.
Old 03-18-2005, 11:40 AM
westy44runner's Avatar
33s also...given its probably only slightly lifted...this way down the road you can do your own lift...and do it right...instead of buying a pre lifted truck probably riding on superlift/skyjacker/rancho springs...no thanks
Old 03-18-2005, 12:22 PM
az4x4runner's Avatar
33s and a locker. Partially because I wouldn't want anything much larger than 33s anyway.
Old 03-18-2005, 01:49 PM
Tacoma750's Avatar
the truck is stock. Im sayin, what would you rather build for your DD?
Old 03-18-2005, 02:20 PM
Bob_98SR5's Avatar
Tacoma750,
Again, please try to make your topic threads clear and concise. Please, no lead on questions as thread topics. See sticky: https://www.yotatech.com/forums/f2/please-make-your-thread-topics-easy-read-understand-53802/
Thanks,
Bob
Old 03-18-2005, 02:26 PM
Tacoma750's Avatar
sure thing man..
Old 03-19-2005, 12:56 AM
4RunnerKid's Avatar
33s and locker. Trust me...
Old 03-19-2005, 05:24 AM
Cebby's Avatar
33's and lockers.
You only gain an inch of clearance with the 35's and without lockers, you are really only 2 wheel drive.
Old 03-19-2005, 06:55 AM
netwt12's Avatar
go with the locker
Old 03-19-2005, 06:59 AM
calg3's Avatar
Another vote for 33's and lockers...
Old 03-19-2005, 07:37 AM
JuttyShabango's Avatar
33s and lockers. That's what I run right now as a DD. My rear diff is even welded.
You'll be amazed at who you can follow and where your rig will take you. Oh, you may drive on the side a little.
Jutty
Old 03-19-2005, 09:04 AM
deathrunner's Avatar
33's for sure
Where do I begin:
Cheaper (33's cost less, and require less lift)
More reliable (Gonna break less stuff)
More traction (Any time a locker/no locker scenario comes up it's a no brainer)
Less Trimming
Tested and proven
Old 03-19-2005, 09:33 AM
waskillywabbit's Avatar
35s and lockers
I got my 35/12.50/15s cheaper than a set of 285/75/16 (33s) by $40 a tire which almost pays for 15 inch steelies. If you are going to get tires anyway (285s) and you got the lift to do it, get 35s and lockers.
Old 03-19-2005, 11:20 AM
Is this IFS or SA?
I assume you mean IFS...in that case I stand by my words
If you mean SA then by all means 35's and lockers
Old 03-19-2005, 03:49 PM
Tacoma750's Avatar
well it is IFS. I do not have the $$$ to do a SAS or i would have done it by now. With that being said, im going to run 33s, just to be nice to the IFS. I will run lockers as well. My plan is to have this truck as a DD but be able to do the ocassional mud romp in it. Thanks guys.
Old 03-19-2005, 04:06 PM
dragr1's Avatar
33's and a rear locker for an IFS rig
Old 03-19-2005, 05:14 PM
Flygtenstein's Avatar
If you want to wheel it, lockers will get you farther than open diffs assuming otherwise identical trucks. Tire size is pretty inconsequential.
33's are a managable DD tire, but 35's are not unmanagable.
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
83yotastockR
11
11-10-2015 06:54 AM
Toys4parts
09-26-2015 01:56 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: What would you rather have? (33s + lockers vs 35s + no lockers)
