Yota Trash's build up
Thanks. Nobody was injured. It's gonna be a project but they always are. The frame is straight I just need to build some tube supports and sas it to get it back on the road.
mock up
picked up some front end parts at the scrap yard today, still needs paint just wanted to do a mock up. also picked up everything i need for my axle swap.
No way, you got this.
As for a wheel well, try a junk yard, or search Craigslist for some one parting out a truck and cut one off that. Can you post up a closer picture of what you need to re hang on the wheel well, and where youll be welding it on? When you cut it off the donor cab, remember to cut way more than you need and can trim at home.
Hows the core support/ front body mount?
Since the junk yard wouldn't let me bring a saw in I was going to do tube inner fenders that I made and sheet metal for wheel wells. just not sure how bending that sheet metal goes and how to make it strong enough to hold up the weight of the battery.
This was my first shot at welding.
Bent Housing
Finally got all my SAS stuff and went to put my axle together after work only to discover the my housing is bent so now everything is back on hold.
Front inner fender will be welded back together when I do the SAS.
If you know anyone selling an axle housing let me know.
jasonty
41
12-23-2018 01:00 PM
Jcrawl94
10
10-24-2015 04:34 PM
FS[PacSouthWest]: 1985 P/U Xtracab Old Dirty Worn Carpet
shisha1999
08-24-2015 03:40 PM
priest16
15
08-06-2015 07:43 AM
