94-22re head rebuild and major tune up questons
ok i have a 94 toyota pickup 22 re 4wd 5-spd. wen i bought the truck it had 130,000 on it and i had the timing chain replaced with the good kit with the steel guides and it seemed ok untill about 2 weeks ago i started the truck and it was running wierd, so i shut it off rite away and noticed that the anti freeze had oil in it and was over flowing, i did not run it after that, pretty sure i didnt over heat it, started leaking oil up front a couple of months ago. the mechanic that did the timing chain did not replace the head gasket and he did not remove the oil pan wen he replaced the timing chain. the truck now has 160,000 miles, so i got a head gasket kit and had the head re-surfaced checked for cracks and a valve job done. im glad i removed the timing chain cover because the gasket was bad, got a new timing chain gasket the chain and guides look fine, thats where im at now trying to take my time taking the oil pan off, its really on there lol. 1 the questons i had was how do i prime the oil pump wen i put it back together, by the way the engine is out of the truck, also the one freeze plug looks like its pushed out just a little further than the others, 2 should i replace them or just leave them alone, also got new fuel filter, ngk plugs, wires, cap, rotor, thermostat, head bolts, engine mounts, and new clutch. also the truck has no oil pressure guage, 3 wasn't sure how i could tell if the oil pump is working properly with out a guage. 4 also noticed that just behind the dip stick on the block 22r is stamped? thought it would be stamped 22re ? 5 also the oil pan has gray gasket sealer on it rite now i have some black gasket sealer which color is the best for the oil pan and for the corners of the head? 6 also what should i do with the fuel incjectors? the kit came with new o-rings, what can i clean the injectors with? guess i should also add that im not trying to gain extra hp just trying to get another 150,000 out of the truck, its my daily driver, im also painting the frame rite now since i live in pa and everything rots out here lol but anyways i have all the parts i need now and today im going to try to clean up the top of the pistons and block, and try to get the oil pan off and start re-assembling, any help and tips would greatly be appreciated
performancewitch.com for the injectors. I perfer purple sealant, j/k any will do fine. Don't prime the oil pump on a 22r/re. 22r is block 22re is the intake so relax. you should do the rear main since it is out and tranny front seal. New clutch kit.
Replacing the head gasket on a timing chain replacement is not necessary so you mechanic did not rip you off. But use factory head gasket anytime you replace one.
probably ought to replace water pump while you got it off. remember to use antisieze or you will wind up replacing the timing chain cover.
ok well i got busy today but now im back at it cleaning up the timing chain cover and oil pan any tips on cleaning the top of the pistons and the block? after everything is cleaned up ill be ready to start re-assembling and water pump is pretty new and have all gaskets going to use ultra black silicone on the oil pan i guess ill also remove the oil pickup and try to clean the screen too. ill also put rear mail seal and front main seal in since i have new ones.
ran into an other problem i wanted to run a tap in the block for the head bolts, 2 of the holes are really full of carbon, i cant find the right size tap 12mm-1.25 is too big and 12mm-1.5 is too small , i need to just go get a snap on tap and die set when i get the money, but i was trying to get this finished this weekend now its sat. afternoon and most stores are already closed. worst part is this is my dd.
Where in Pa do you live??
Why would you not prime the oil pump.
I always do since it has been out and cleaned checked for clearance or when installing a new one.
Just curious.
You have the engine out it would have been a easy job to do the bottom end this could come back and bite you in the butt.
No reason to buy a complete Tap and die just get the ones you need along with the correct tap drills needed.:jessica:
Just curious.
i like to use the gray stuff i have been in a pintc before and made motor mounts out of that stuff and oil will not bother it. do the read mail check the clutch and put a pilot bearing in it dont forget to clean the oil pick up screen and use anti seas on the watter punp
i live in york pa, should the oil pump be primed or not also noticed that my new head bolts are a little over an 1/8inch longer that the old bolts nothing is going right lol
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
