91 4runne wont start.
I pulled out from my ally across the intersection running just fine. Let my foot off the throttle heading sown a small hill engine shuts down. Now all it does is crank no start. New ngk plugs, wires, cap, and rotor 3 days prior. Has fuel has spark. Timing belt is on don't know if in time but its not broke. Anyone have any ideas
I would suggest you charge the battery and do some actual testing of components yourself before jumping on the forum and basically asking us to do all this for you. Research similar symptoms and threads and actually do the tests that others have already done and reported on....
Done research worked on the vehicle prior to battery drain. Only after doing what I could did I asked on the forum. But anyway. Just wondering if anyone has had same sort of problems and could offer other suggestions.
Might try the fuel pump test jumper and see if that does anything different:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
And try checking all the engine fuses. I once had my '85 act up once, engine was still running but lost all the gauges, etc. Pulled over, checked each fuse by pulling it out and inspecting and then re-installed each one, no problems were found. Started back up and everything worked like normal. I suspect a fuse terminal had oxidized in the fuse holder and lost contact. Just the act of removing and re-installing the fuse cleared off the oxidation and all was fine. That was like 14 yrs. ago and has not happened since.
one thing u might want to do is pull the dist, i once got a new one and it bent some how and i would get spart but wrong cly. also look and see how the tube for the intake looks, could have slipped off,
You did your work, it ran fine, and then it stalled? Now you have spark, it will crank but not fire?
This JUST happened to me, I had spark, fuel and air with no firing. Turned out to be a loose ground. I would check your battery connections, make sure it doesn't move around in it's holder, and check all your frame and engine grounds to eliminate the cheap stuff. Good luck!
zombie_barbarossa
10-02-2015 10:54 PM
JookUpVandetti
09-30-2015 08:58 AM
Armstrong486
09-19-2015 12:37 AM
