Sponsored by: CARiD
A/C light does not turn on when pressed
Old Oct 14, 2007 | 03:45 PM
WI_Mike's Avatar
My name is Mike and I've been poking around these forums for awhile now, but I have a question of my own now. I have a 1994 4runner 4wd v6 and when I press the A/c button the light does not even turn on. My mechanic has looked into it but not enough to diagnose the problem (he was busy fixing other problems). Any ideas?
Old Oct 14, 2007 | 04:01 PM
OSU4Runner's Avatar
Does the A/C still turn on when you push the button? If so, its probably just a burned out bulb.
Old Oct 14, 2007 | 04:02 PM
OSU4Runner's Avatar
Welcome to Yotatech too!
Old Oct 14, 2007 | 06:12 PM
WI_Mike's Avatar
Thanks! No the A/C does not kick in. It does something, but I can't remember what my Mechanic said.
Old Oct 15, 2007 | 01:56 AM
OSU4Runner's Avatar
Have you checked the fuses?
Old Oct 15, 2007 | 02:05 PM
WI_Mike's Avatar
I couldn't find them on the panel. I am assuming they are inline. Is there an easy way to do this?
Old Oct 15, 2007 | 02:23 PM
OSU4Runner's Avatar
Check the fuse panel underneath your hood.
Old Oct 15, 2007 | 08:12 PM
WI_Mike's Avatar
Nothing there labeled A/C.
Old Sep 3, 2012 | 09:18 AM
Fishbreal's Avatar
a/c light wont come on no cold air
im having the same problem with my 94 v 6 has anyone found a solution
Old Sep 3, 2012 | 09:34 AM
BigBluePile's Avatar
Apparently not in the last five years....
Old Sep 3, 2012 | 10:52 AM
donomite49's Avatar
add freon, duh !!
forgot to add
holy thread resurection batman!!!
Old Sep 3, 2012 | 11:12 AM
85gijunk4x4's Avatar
HAHA LMAO
well, for future reference, fuses, fusable links, wiring, grounds, make sure the switch itself is plugged in.
Old Jul 16, 2024 | 10:43 AM
jason.freeman's Avatar
I had this exact same issue in my 95 Toyota Pickup SR5 3.0L and it was a fuse that is located behind the glove box.. It is easiest to remove that whole right panel of the dash (glove box included) and there is location with a 30A and a 10A fuse and for me it was the 10A fuse and everything worked.
Old Sep 5, 2024 | 08:56 AM
coronangel's Avatar
you have two fuses behind the glove box, possible a fuse under steering wheel by the left foot. you also have an adjustment behind the glove box with a knob.
note: ac light can be on but a/c not working.
if the light starts working, but still no a/c, you can go to the a/c compressor and jump the clutch to see if that works to eliminate that
MO transplant
Apr 23, 2023 11:58 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
rushw
Jul 18, 2015 01:46 PM
Odin
Jul 15, 2015 09:28 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
