A/C light does not turn on when pressed
My name is Mike and I've been poking around these forums for awhile now, but I have a question of my own now. I have a 1994 4runner 4wd v6 and when I press the A/c button the light does not even turn on. My mechanic has looked into it but not enough to diagnose the problem (he was busy fixing other problems). Any ideas?
Does the A/C still turn on when you push the button? If so, its probably just a burned out bulb.
Welcome to Yotatech too!
Thanks! No the A/C does not kick in. It does something, but I can't remember what my Mechanic said.
Originally Posted by WI_Mike
(Post 50639717)
I couldn't find them on the panel. I am assuming they are inline. Is there an easy way to do this?
(Post 50640352)
Nothing there labeled A/C.
a/c light wont come on no cold air
im having the same problem with my 94 v 6 has anyone found a solution
Apparently not in the last five years....
add freon, duh !!
forgot to add holy thread resurection batman!!! |
(Post 51968218)
HAHA LMAO well, for future reference, fuses, fusable links, wiring, grounds, make sure the switch itself is plugged in. |
