Water Leak help!!
Water Leak help!!
Ok, i have a 93 Toyota Pickup with a 22re, i just had a Jasper engine put in, and discoverd a little leak under the truck,, got to searching and looks like it is leaking from the "thingy" that is under the oil filter,
question is what is that Thingy??
has a wire going to it, and looks round, maybe a sensor, not sure what it is called thats why im asking??????
Well it is possible it is oil,
ive never had a new engine before where the oil is as clear as water, lol
if it is the oil pressure switch, is it possible for oil to drip out of there??
ill try to take a picture tomorrow of it and post it
Engine block heater? Mine is leaking like crazy right now. I think its an aftermarket part installed in a removed freeze out plug... trying to figure out how to tighten mine. Keep an eye on your coolant level!!!!
dang i hope not,, this motor has 100 miles on it,, a jasper install
hopefully just that oil switch or whatever it is called, didnt have a wrench with me to tighten it up to see if that was it,,
and i believe it is oil, just a very small drop or 2 was under the truck this morning and looked like oil
If it's under the oil filter and kinda to the right, it's the oil pressure sender. I say sender because you say it's round. If it were long and skinny, it would be a switch.
Rob
Rob
yes i believe it is the oil pressure sender,
so is it possible that it is dripping out of there, and down on the front running gears and then on ground,,
sound like the right area??
WellsR
12
07-31-2015 03:27 PM
TJWilly
07-31-2015 02:05 PM
Avenged
07-09-2015 07:55 AM
