Transmission Slipping
Old 06-21-2006, 09:59 PM
93yota4runner's Avatar
As i shift into drive and start to take off there is no accleration, the engine only revs up and then eventually it will take off. This happens at every stop i make. Also my O/D light flashes on and off a lot? Anybody have the same problem? I have a 1993 4Runner 4WD 180K miles v6. Any help would be appreciated.
Old 06-21-2006, 10:38 PM
95RunnerSR5's Avatar
check your fluid.....if its an auto i can almost guarantee it is VERY low on fluid...stop driving it immediatly and refill it!
Old 07-04-2006, 11:10 AM
Babypig's Avatar
Try pulling the codes for the tranny. More than likely a shift solenoid is going. Easy to change them out. Grab the codes the same way you do when timing the engine just watch the o\d light instead. You may have to tap on the accelerator to get it to flash. Sounds like a solenoid though. So prepare for the sticker shock at the price of them or try to find one in a junkyard being carefull to get the same year tranny. Some of the solenoids have different specs.
Old 07-04-2006, 11:18 AM
waskillywabbit's Avatar
I'd check the fluid level as mentioned, fill it and then take it for a flush before doing anything else. Not a drain and refill, but a flush. Friend of mine had the exact same issues and a flush and refill fixed his problems. The more expensive alternative will still be there if that doesn't work.
Old 07-07-2006, 09:47 AM
Yosemite Stars's Avatar
tranny Fluid can get OLD
Hi...To add to the others remarks - My car was slipping from 1st to 2nd and I just had old used up tired fluid on my 1986 22RE...Plus did the seal kit...Good Luck!!
Old 07-20-2006, 08:16 PM
4banginRunner's Avatar
wow i have found someone with the same problem!! i m glad i searched b4 posting a new tread... i need to try flushing my trans i guess...(22re/at, at idle and driving the o/d light blinks repeadativly..)
Old 07-20-2006, 08:21 PM
yeah man dont drive it until you make sure you have enough fluid...the same thing happened to me and my main seal around the output shaft didnt have enough fluid to stay lubed and it wore out....causing me another weekend of work..
Old 07-27-2006, 11:00 AM
found out that the o/d light blinking is a tranny trouble code.... will be addressing that soon...did some searching and found out it is either a shift sensor or a speed sensor... i will post an update when i get things sorted out...
Old 08-25-2006, 06:11 AM
nineball's Avatar
What did you find out? Mineis doing the same thing, I just replaced the speed sensor and it is still doing it..
Old 03-31-2010, 09:59 AM
arthurpwiggle's Avatar
Any update on this problem?
I'm having the exact same problem as mentioned by several people above. Is there any update as to the cause/fix?
Old 04-04-2010, 06:34 AM
yep junked 2 toy auto's and swapped in a 5spd, best mod everrr
Old 12-12-2010, 12:53 AM
turbodrifter's Avatar
my Transmission would seem like its slipping on low RPM or on full Throttle its like slipping or drops RPM its hecka weird its fine when i drive at 3000RPM
Old 08-09-2011, 06:10 PM
93_4runna's Avatar
After about dumping 2k into my runner after purchasing it used the tranny seems to be acting up with 250k... I know that's a lot of mileage and they don't last forever but here's hoping i can get more out of it.
My problem is about 50% of the time (mainly when its warm) i take it out of park and put it into reverse or drive nothing happens. By putting it back into park and trying again sometimes it starts working again.
Once its in drive it works ok but accelerating from low gears i've noticed it revs quite high before shifting, especially on cold take off.
No idea when or if the tranny has ever been flushed but checking the level it was overfilled so i drained a pint but it did no difference.
I've read weak springs in the tranny can cause this does anyone think this could be the problem? Should i try a tranny flush first? probably the cheapest bet.
Thanks
Old 08-11-2011, 05:33 AM
93_4runna's Avatar
I looked online and it might not be a good idea to flush with 160,000 miles on it... I think i'll try to determine if the problem is electrical or mechanical first but i don't know what kind of tranny i have (A340e, A340f or A340h) it's a 93 4Runner, Auto, V6, 4x4. Any help would be appreciated, thanks.
camel_65@hotmail.com
10-03-2018 06:11 AM
justdifferentials
14
06-11-2017 08:36 PM
briholt
09-20-2015 10:26 PM
93toyoguy
3.4 Swaps
10
09-18-2015 04:16 PM
kelly1450
09-02-2015 12:29 PM
Quick Reply: Transmission Slipping
