1988 4runner that i want to put on a 1985 pick-up frame
Old 06-05-2009, 06:41 PM
ykwildtoy's Avatar
i have a 1988 4runner that i want to put on a 1985 pick-up frame for the solid axel. is this possible for a direct bolt, and just put my 22re in or not the pickup engine is a 22r
Last edited by waskillywabbit; 06-06-2009 at 02:01 PM. Reason: useful title for searching
Old 06-05-2009, 07:56 PM
4rnr's Avatar
very possible. Just a body swap? or are you going to swap over a couple of the "more desireable" parts from the 4runner (rear axle, steering box if you think you will go high steer, brakes etc...) regardless it should work. Even if the body mounts dont line up make some.
Old 06-05-2009, 11:57 PM
Sponsor
Tofer's Avatar
why not just use the front axle on the 88 and get a SAS kit?
Old 06-06-2009, 12:03 AM
CRafferty's Avatar
^ Because that would be much to easy.
Unless the 4R fame was bent to who knows where or rusted out.
There has to be an underlying reason.
Old 06-06-2009, 03:42 PM
ted
ted's Avatar
x2
Old 06-06-2009, 09:52 PM
myyota's Avatar
Yea, just do an axle swap, it would be a whole lot easier and a lot less work.
Old 06-07-2009, 11:35 AM
ykwildtoy's Avatar
there is a method to my madness the frame was modified with chevy springs and dana 60's , i do think an sas would be easyer but where is the fun in taking an easy way i love to fab and if i could pll this off my truck would be a tank
Old 06-07-2009, 11:47 AM
Staff
DeathCougar's Avatar
It will not be a direct swap. The mounts are different, and will have to be fabbed to make it work.
arlindsay1992
01-23-2024 01:34 PM
JF9243176
10-08-2017 04:21 AM
JF9243176
06-24-2015 04:53 AM
Eagle564
06-23-2015 11:29 PM
JaredL
06-16-2015 04:47 PM
Quick Reply: 1988 4runner that i want to put on a 1985 pick-up frame
