Help! Engine lopes after Head Gasket replaced.
I just replaced the head gasket on my 85-22-REC engine. And now my engine lopes or modualtes engine speed up and down when I accelerate and hold position. EFI was working fine when torn down. Anyone got any suggestions? I have checked my vacuum lines and there doesn't seem to be any gasket leaks.
Thanks,RWade
Thanks,RWade
Check the ECU for codes. Sounds like something awry in the EFI. Read this link if you need help with that.
http://www.off-road.com/toyota/tech/codes/
Thanks,RWade
Thanks,RWade
First make sure the throttle is fully returning to closed position. If not, fix that. If it is, and problem is still present, adjust the TPS.
